Ok So i have a 2021 sierra elevation crew cab. I am wanting to change the wheel set up. I love the look of 12" wide rims but don't want rubbing. So I was considering a 10" wide rim. What leveling kit do you guys recommend to preserve the factory ride?
There are a billion posts about this already and 5 minutes of searching would go a long way.
However, the bottom line for "just a level" is as follows:
If you want to do a spacer level, then brand is irrelevant and they all do the same thing.
If you want to do a suspension level, Bilstein and Eibach are quality setups that most people go with.
Edited by Gangly
I have the same truck, and installed the factory leveling kit.  I gained two inches up front and it looks great.  I have the factory wheel set up, but put on 33x12.5 BFG MT KO3 Tires.  No rub, great look, factory ride... hope that helps
Edited by Adam Shell
added pics
I installed Motofab 2.5" upper leveling kit my self and also added a 1" block in the back.  If you do consider doing your self be very careful with cv axles to not stretch and rip boots also get an alignment done after.
Probably not what you want to hear, but I wouldn't install one.  They look good, but they all compromise the ride, they make it hard to get perfectly aligned, and I've experienced issues with the truck eating ball joints since the install.
Granted, that was all on my 2015 Silverado, not my 2020 Sierra, but still...
Where did you get the 1 in block from?
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
