I Use it to hold my wallet to pull out a credit card for the places that don't use Apple Pay.
That's about it.
I used to use it for my business cards until I got an under-jump seat lock box to store my cash in.
Had to put the business cards into the console so they wouldn't fall out when I accessed the lock box to pay my yard guy or my car wash guy.
BTW, there is a great pen holder under the lid of the console.
Edited by MikeBMW
I put my phone in it just upside down. Since there is really no place to plug it in and lay it down. I tried on top of the console but if I have to hit the breaks, it goes flying lol.
I use a Quad Lock case with the Quad Lock mounts: one for my bike, anther three desk mounts for home office, office and bedroom nightstand as well as an arm band for my running.
Here is a short video of the one in the truck. If you have heated and/ or ventilated seats, you may have to find a different mounting place.
(quality may be a bit low, I had to use my old 7th gen iPad to do the vid and show the iPhone and mount, Also, sorry for the vertical vid)
Center console looks great!
But, hash browns (McDonalds) are DELICIUOS!!! Salsa might be on to something, rather than a Texas Edition, how about an Idaho Edition, with hash brown, and French fry holders throughout the truck🤔😬
Expand the HB holder to be able to put your favorite dipping sauce beside it!
Think we have a new marketing campaign in the works, the McDonalds edition, BK edition, and so on...
  • Haha 1
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,242 Guests (See full list)
