Hey so I bought a 2018 Silverado and threw a 4 inch suspension lift ...I'm only gonna be rolling 33's-34's (285/75/?) Or 285/70/?
I have stock 17 inch rims which will not be staying on the truck  so I'm looking into 17x9 or 18x9 rims...now the tires I plan on running are only 11.5 inches wide at best but I would like them to hang out maybe a inch or so....I'm not very smart when it comes to offsets and I have read so many mixed things online that I'm a little lost as to what I should go with ...anybody out there running -12 to -19 offsets with the same setup? .....this is not a ...oh how big of tires can I fit ...or how much lift do I need thread....just looking for some opinions of people in the same boat and what they ended up deciding on....thanks
I have been on that site maybe I'm doing it wrong but I enter my info and it shows me pictures of all sorts of offsets but they all seem to look the same whether they are positive or negative offset that's where I got the idea for -12 to -19 because that's the rims they recommend me but I didn't see no pictures maybe I need to look harder was just hoping someone had some input on the subject from personal experience
I have been on that site maybe I'm doing it wrong but I enter my info and it shows me pictures of all sorts of offsets but they all seem to look the same whether they are positive or negative offset that's where I got the idea for -12 to -19 because that's the rims they recommend me but I didn't see no pictures maybe I need to look harder was just hoping someone had some input on the subject from personal experience....edit ...okay I'm retarded I didnt click on the gallery section on custom offsets
The factory wheels are around +24.
If you go with a -19 , it's going to stick out 43mm farther than stock. Or about 1.7"
13 minutes ago, Tony Barry said:
10.5 lift! Did you have to get custom drive shafts built ? That's a sweet looking truck man
Thanks Bro.
Driveshafts are stock .
Mcgaughys 9" lift
Zone 1.5" body lift
If you are into big lifts on half tons this is your goal.
Edited by dieselfan1
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
