Did you move the camera up while making a grille change? The front camera is either higher that it’s supposed to be, you have the wrong camera part number (with wrong magnification), or some sort of magnification software setting is wrong as you are thinking.
If you didn’t change the grille and camera location, I would take it to the dealer and ask them to fix it.  That’s not the way it should appear. Mine lines up parking lot lines perfectly.
I looked again closely, and mine doesn’t actually line up perfectly, but it is very close to perfect, with maybe 1/10th of the difference yours shows. I see a very slight offset of the parking lines on mine - less than 1/4 of a line width - in a similar parking line view, with the front camera view being slightly enlarged like yours.
  • 1 year later...
I have this same problem with my 2022. There is a huge disconnect between the side camera views and the front & back looking cameras.
There is no excuse for this, the images can easily be aligned with calibration in software, either manually or automatically. We just need to know how to start the calibration process.
  • 1 month later...
    1981dustin
    1981dustin
  • Who's Online   4 Members, 0 Anonymous, 1,588 Guests (See full list)
