Hey guys! I’m replacing the compressor in my 2015 Silverado LT with the 5.3. After replacing both my condenser and upgrading to the steel discharge line, as well as adding the bracket, my compressor started leaking from the back a few days ago.
So I got the replacement GM genuine compressor, expansion valve, and a desiccant bag. I’m wondering what the torque specs are for the nut that holds the suction and discharges lines to the compressor, as well for the nut that holds the lines to the condenser and expansion valve. I’m assuming since they all have the same stud, they should all be the same torque spec. Also, while I’m here, can the desiccant bag be replaced with the condenser still in, or do I need to remove the condenser to replace the bag? Thanks all!
16 lb ft. Per GM, the condenser will have to come out.
You shouldn't have to use any additional sealing liquid. If it's leaking, the leaks would need to be repaired.
Two reasons I can think off that would cause freon to leak from compressor; 1, Bad compressor. 2, you have a blockage in your system causing very high pressure.
hey there. I was told the sealant isn’t needed but helps, so I’ll probably add it. Dealership said that the pressure reading of output on compressor was alright but it’s leaking from the back. They said everything else was fine. So I’ll be replacing compressor, expansion valve, all seals, and removing condenser to replace the desiccant bag
I have never used sealer. That is what the seal is for.
I’ve been told the nylog just helps the protect sealing washer and o-rings from heat and the elements, and it can go on flared fittings to help seal, seen lots of good reviews on it
Use it if it makes you feel more comfortable. Belt and suspenders approach I guess.
Since your are replacing all those parts, make sure to use the correct oil. The oil that comes inside the compressor may not be the correct type. Always double check.
Yeah, I figure if it can help, why not. I really don’t want to do anymore AC work on this truck, so I’m hoping this should help. I’ve been reading lots of good things about the blue nylog so I’m more confident in it
I’m not going to be doing any oiling, I’m just going to install the parts, then take it to the dealer for the vac and recharge. I’ll explain my situation to them and they can handle the rest hopefully
I'm an HVAC tech by trade. Though the fittings are different I use a sealer on any joint that does not require torches. Nothing like added security. I started with nylog then moved on to Liqivac. With nylog you want to make the surfaces/ oring clean with alcohol or acetone to aid in adhesion. Put it on lite so it does not squish into.
I do agree a fitting shouldn't need a sealer, but with the quality of things it can't hurt.
Edited by Snowcamo
I get what you are trying to do. Please note, all new compressor comes with oil to keep it lube. Some comes with the correct oil type while others do not. It's important that you check as you don't want to mix the two oil together in your system. You probably will end up paying more than the money you're trying to save.
Why not just take the parts to the dealer and pay for installation labor, atleast it will be done right. I don't know how much the dealer will charge for a complete system flush but I can only imagine $$$$$$$$
i wasn’t aware I needed to clean the sealing washers with acetone, good thing I have some here! I seen online everyone said the nylog was like nickel anti-seize, a little bit goes a long ways! Thanks for the info!
    tblt44
    tblt44
  • Who's Online   6 Members, 1 Anonymous, 561 Guests (See full list)
