Hey guys! I’m replacing the compressor in my 2015 Silverado LT with the 5.3. After replacing both my condenser and upgrading to the steel discharge line, as well as adding the bracket, my compressor started leaking from the back a few days ago.
So I got the replacement GM genuine compressor, expansion valve, and a desiccant bag. I’m wondering what the torque specs are for the nut that holds the suction and discharges lines to the compressor, as well for the nut that holds the lines to the condenser and expansion valve. I’m assuming since they all have the same stud, they should all be the same torque spec. Also, while I’m here, can the desiccant bag be replaced with the condenser still in, or do I need to remove the condenser to replace the bag? Thanks all!
You shouldn't have to use any additional sealing liquid. If it's leaking, the leaks would need to be repaired.
Two reasons I can think off that would cause freon to leak from compressor; 1, Bad compressor. 2, you have a blockage in your system causing very high pressure.
hey there. I was told the sealant isn’t needed but helps, so I’ll probably add it. Dealership said that the pressure reading of output on compressor was alright but it’s leaking from the back. They said everything else was fine. So I’ll be replacing compressor, expansion valve, all seals, and removing condenser to replace the desiccant bag
1 hour ago, tbarn said:
I have never used sealer. That is what the seal is for.
I’ve been told the nylog just helps the protect sealing washer and o-rings from heat and the elements, and it can go on flared fittings to help seal, seen lots of good reviews on it
Use it if it makes you feel more comfortable. Belt and suspenders approach I guess.
Since your are replacing all those parts, make sure to use the correct oil. The oil that comes inside the compressor may not be the correct type. Always double check.
Yeah, I figure if it can help, why not. I really don’t want to do anymore AC work on this truck, so I’m hoping this should help. I’ve been reading lots of good things about the blue nylog so I’m more confident in it
I’m not going to be doing any oiling, I’m just going to install the parts, then take it to the dealer for the vac and recharge. I’ll explain my situation to them and they can handle the rest hopefully
I'm an HVAC tech by trade. Though the fittings are different I use a sealer on any joint that does not require torches. Nothing like added security. I started with nylog then moved on to Liqivac. With nylog you want to make the surfaces/ oring clean with alcohol or acetone to aid in adhesion. Put it on lite so it does not squish into.
I do agree a fitting shouldn't need a sealer, but with the quality of things it can't hurt.
Edited by Snowcamo
I get what you are trying to do. Please note, all new compressor comes with oil to keep it lube. Some comes with the correct oil type while others do not. It's important that you check as you don't want to mix the two oil together in your system. You probably will end up paying more than the money you're trying to save.
Why not just take the parts to the dealer and pay for installation labor, atleast it will be done right. I don't know how much the dealer will charge for a complete system flush but I can only imagine $$$$$$$$
i wasn’t aware I needed to clean the sealing washers with acetone, good thing I have some here! I seen online everyone said the nylog was like nickel anti-seize, a little bit goes a long ways! Thanks for the info!
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
    • Hello Guys I'm new to the form,         I just put a 7-inch Rough Country lift on my 2016 GMC Sierra 1500 with the 5.3 and I also put a Borla exhaust on it. But I noticed when I'm in park or in neutral and then I rev my truck up really quick there is a bad click noise and I think it's coming from the motor somewhere. Anyways I got a video of it I will attach below I was just wondering if you guys think its rod knock or lifter tick or something like that because I know the AFM kind of made the lifters weak on these trucks.       Thanks!!!!! RIP - Chevy 5.3 IMG_6043.mov
    • We’ll have to agree to disagree. I didn’t experience or know anyone who had a decent car after 100K miles in the 60s through the 80s that were daily commuter vehicles. Unless they were collector vehicles. Of course things cost more due to inflation. But we also make more money. The biggest money drains these days are things people think they need today versus what we require back in the day. Like cell phones and internet as examples. Another example is where you live. Cost of living varies from state to state. I would need twice the money to live in NJ vs Texas in retirement. The car you recently purchased was less than my first car with inflation at 3000$ in 1973. I didn’t have air, electric windows, cruise etc. Purchasing power is equivalent, you just have to do the research.
