Given your chart GB, and the anecdotes we've seen here of what I think were 10L80 transmissions running consistently at 200 degrees and higher under light-ish towing loads I'm very pleased that mine stays around 145, even in high ambient temps. Of course the proof will be in the pudding when I actually pull one of my trailers, but at this point it appears that I won't see temps in the "dangerous" ranges for my tranny.
Sleeve bearings have been about a thou per inch of diameter for over a hundred years. Piston clearances have changed back AND forth. I've heard there is a new forging alloy that can be fit as tight as a cast piston. That would be big news for small inch boosted OEM's but would have nil effect on oil weight. Hypereutectic cast pistons have/are used in Harley Davidsons at a thou bore clearances and still use 20W50. Yep, allot of smoke and mirror marketing.
Lower viscosity, lower AW levels (sacrificial chemistries) and longer OCI's depleting them. Toss in some poor QC not catching machining issues and it's amazing they lasted as long as they have.
Side note. that 0W* v 5W* noise is just that. Noise. Unless you live where it's > -22 F constantly. Zero weight is another fuel play. It's actually the majority of the fuel savings in a light weight oil. In my zip code we've had two days in a decade that it has been the cold. On those days both Pepper and I call in sick.
O2's not working well will alter the AFR and make em stink.
Drop that cat in a bucket of hot soapy water then pressure wash the internals, what you can reach. Brings a good many of them back to life if it's soot and not poisoned.
