I have a 2015 half ton WT with a 5.3. About a week ago it started cutting off while I was driving it. It was like the switch was turned off. After a second or two it would restart on it's own. I checked grounds and fuses and reseated some connectors and it got better for one trip to town, but on the next trip to town it died and I haven't been able to restart it since.
I replaced the battery about a month ago because the original battery failed. It ran fine after the battery change.
I have removed and cleaned every ground I could find, and rechecked all the fuses. All good.
When I turn the switch to run, everything comes on as it should. When I go to start everything goes totally dead. When I release the key back to run it all comes back on and the gauges all cycle just like when I first turn it on.
In the fuse box under the hood, the run/crnk relay #64 has 12v at the contact side but isn't getting a signal voltage to close the contacts. I can close the contacts manually and it powers up everything downstream - ECM relay, stater relay, and the fuses related to it. With the relay held closed I can start the truck and it will remain running until I release the relay.
I did replace the ignition switch but it didn't make any difference.
Any ideas?
I would put a multi-meter on the battery and watch the voltage when turning the switch.
For fun - take a jumper cable and go from engine to battery ground (ground the engine to the battery). I had a car do as you describe, adding an engine ground strap cured it.
I've also got bad new batteries - twice in a row - that's why I'd watch voltage on it.
It's a long shot, but the battery cables could be corroded inside the casing not allowing current flow.  It's rare but happens.
Good call, 5 days later one of the many 1000's of members actually ready what the OP said.
I am guilty of grazing right over that comment.
It is fixed. I went to check the splice under the drivers door sill and found that a piece of gravel had rubbed through a wire. It was light green with a purple tracer. I had checked that area before and vacuumed out a lot of dirt and small rocks but didn’t see anything. At the time I was just checking the condition of the splice. After double checking everything else three times I went back in and found the problem by running my fingers along the wires and felt a tiny rough spot. I had to look really close to see the problem. I could see a little bit of silver so I knew the conductor was exposed so I bent it a little bit and could see that it was rubbed through.
I’m attaching a picture. In the picture I had just peeled it back a little and twisted the ends together to test it. Afterwards I put in a proper splice and heat shrink
👍 for finding the cause. Another 👍 for coming back to report the cause. A lot would just stay quiet and not report back.
Edited by CrawlSlow
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
