Hello, I have a 2007 Yukon XL 1500 5.3 4wd. The left front area has a humming/vibration when going above 40 and I have feel it a little more when slightly turning wheel to the right. Now before you say wheel bearings, below is the work I've done in the last month and in the order I did the work. This thing is driving me nuts. I'm not a mechanic... just a guy who owns tools.... trying to learn.
About a month ago I started to hear a slight humming from left front, which got substantially worse pretty quick. I could hear it loud and clear going 30mph. I replaced the hub assembly (moog from Amazon). At the same time I replaced the caliper, pads and rotor (all AC Delco off Amazon- caliper was reman). Went for drive and the noise was gone! Well.... until I hit 45 mph anyways, then it was back but not as loud but enough friction to create a subtle smoke when I got home after taking on freeway (at night, I could see the smoke with my flash light). I did some research, I see a lot of people saying a collapsed brake hose. So I then replace that. Didn't fix the issues. Then I purchased half shaft and replaced that. Didn't fix anything. Then, I thought, the new hub assembly I put in, it atleast got the noise half better so maybe it was a faulty hub assembly? So I got a carquest hub assembly from advance. Just got done replacing the hub assembly AGAIN. While doing it, I noticed the pins on the caliper bracket stuck in all way and wouldn't budge. I got those free, lubed them and get them functioning again. Is this relevant? I have no idea. Anyways, took for a test drive and the noise is still there but probably half of what it was with previously replaced hub. Any feedback would much appreciated. I've just about had it with this truck! Thanks
Aaron
Check the other hub bearing . They can fool you sometimes. We run them in 4wd on the lift and put your hand on the tow hook in the chassis . You can usually feel a rough bearing right threw the hook.
Even with smoke coming from behind left front wheel?
It was smoking because the pins seized. That caliper needs to float. The pads also need to move freely on the shims in the caliper. I stopped buying parts at Advance for this reason - every brake component I've bought there has required modification to work correctly. Got tired of grinding pad tabs down. Things shouldn't fit that tight.
Whenever I do front end work, everything gets done in pairs for this reason. I hate comebacks. Always do both hub bearings.
    smandy
    smandy
  • Who's Online   1 Member, 0 Anonymous, 523 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
