Needing some help. The overhead Console in my 21 Elevation has 3 wire harnesses (2 to the console and 1 unplugged). I am wondering what is the unplugged harness for? I see that in the Denali it is plugged up to something. Keep in mind I dont have power rear view mirror or a sunroof or HUD. I am trying to find out what the harness is for. I am wanting to tap into it for my radar instead of wiring to the fusebox. I dont have a multimeter with me at the moment and was wondering if anyone knew?
Was referencing:
 as to the harness was plugged. my elevation has it plugged to nothing.
So far I've Concluded that red/green is battery + Voltage.  Black is ground. Not sure about the others. I am pretty sure this is powered but like i said no voltmeter atm.
Thanks.
The auto dimming mirror harness is glued to the roof, so it is not that.     Do you have homelink or rear sliding window?  Might be a harness for that.
I just installed homelink, and had to pull my old console down, and noticed the unused harness. no rear sliding window.
It could be but I was going over the wiring diagram and couldnt find anything on it. I was referencing the 10way pin and the colors on the pin numbers. couldnt find anything even close.
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 629 Guests (See full list)
