Few days ago my truck went into reduced engine power.
so far I’ve replaced the grounds, throttle body, and gas pedal assembly.. and it still goes into reduced engine power. Gives me code u0107. Happens whenever I hit a bump hard enough.. what could be the issue?
So, did you do the grounds on the frame extension below the drivers side door, facing the rear of the truck?
 If not, better get those wires and frame clean, and cover it with marine grease after.
