Okay so this has me a little stumped. It has a fairly fresh jasper trans, fresh fluid and filter, . Around 45 it starts to buck in a way basically trying to lock in tc and out if I am applying light gas, if the rpm is above 2300-2500 it is smooth as glass, get it up to about 60+ it doesnt do it at all just smooth sailing no matter how much gas you give her. I have functioning cruise control, I am not missing gears or experiencing any slippage else where nor any weird or delayed shifts. I have ran some lucas antislip stuff in it and seems to lighten a little but not much so I am trying to figure out if I should be hunting down sensors or saving for a good t.c. when I changed fluids theres no evidence of shavings in it other then the normal slight wear which the fluid before I changed it was honestly beyond gone as in looked like a century old motor oil with a red tint level gone but smelled like trans. Which trans acts just fine other then that 45+ areareceived_345006547032870.thumb.jpeg.acc17088af3cabcb332c3627da1b8769.jpeg
Just now, Supreme Pizza said:
Is that your transmission fluid? Or the creature that killed Tasha Yar on Star Trek The Next Generation?
Oh yeah was nasty stuff man. But like I said nothing in the pan other when just a wee bit of normal wear. No chunks no glittery shavings etc. It definitely had something go wrong either was abused, they cheaped out and reused fluid, or someone accidentally dumped some motor oil in it. Which next week im doing another clean out just to make sure I got everything that was left over. But im trying to get w feel on what else to do, im no tranny guy by any means but motors I know, just havent found much support with trouble shooting the code
It looks like the fluid is being burned. If you are just draining the pan, then you would need to:
Drain, Refill, Drive.
After 3 times you would probably have 60% new fluid.
The fluid condition indicates that your transmission may not be performing correctly, and the imminent failure is possible. Maybe the bad fluid is causing the problems, but probably not. Its worth a try though, replacing the fluid.
Drain plug trans pan would be worth installing, to save time.
Edited by Supreme Pizza
Yeah ive already changed it one and a half times( yes half to drain and add lucas and some fresher fluid)  will be tanking it for a full system flush next week after the holidays. Which it was only that color when I first got this thing not that long ago, which I doubt it just fluid issue too hense why I am trying to get more ideas on where to start trouble shooting this thing as I have only found a single forum on it and their symptoms was not like mine
Jasper has been sucking lately - lots of friends of mine have been dealing with comebacks left and right due to Jasper installs. Not sure what's going on over there, but they're not the company they used to be.
The transmission is JUNK - whoever installed it needs to warranty it. No question about it. Black is clutch material. It's toast. You dumping that mechanic in a can stuff might have screwed you, though - you could get denied when they tear that one down. That stuff makes the valve body gaskets, which normally peel right off, stick like glue to the valve body. It also swells seals up, making actuators and clutch assemblies extremely difficult to disassemble. As soon as they crack it open and smell that, you might be screwed. Hopefully a decent shop installed it. It was clearly built WRONG.
I know of 2 places - one in Amarillo, TX, and the other in eastern / central PA that built top-notch transmissions if you're close to either. Even if you're not, the PA one ships. The guys in TX don't like to ship their products out because so many people destroy them upon install. Have to know what you're doing. You can turn $5,000 into scrap instantly.
Edited by Jsdirt
Trans was previously done before I got it and  I am only about $1900 in the vehicle total minus tires including buying and titling etc. So dont mind if trans is shot after all. But the weird part is its only in that one speed section at a low rpm thats what gets me.no other trans symptoms
Edited by Timothy Reyn
Torque converter could've failed where it's not releasing from lockup. Or there's a short to power in the lockup wiring. I can only guess from here.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
