When I leveled the front end of my 2500, before I did any work I drove into my garage, turned my lights on and using electrical tape marked the floor where my front tires were, then the wall above and below the brightest portion of all the lights including the fog lights. Made the change to my keys and shocks. Leveled the truck, then turned my lights back on that are now higher on the wall, adjusted them down using the screw mentioned behind the light fixture until the beams are exactly where they were stock.
On 2/27/2025 at 9:55 PM, Another JR said:
Pictures as mentioned above. The Allen wrench is a 6 mm, roughly 6 inches long.
Do you happen to recall which direction screw turn was up vs down?
This procedure likely has your headlights pointing down a bit more than they should, unless your garage has a LOT of space between the headlights and the wall you put the tape on.
I don’t, but as soon as you start turning the adjustment it should be obvious which way it’s moving.
Whenever I do an adjustment like this I count turns so I can put it back where it was if I decide I screwed something up.
Edited by Another JR
Typo
Is there any provision for adjustment from side to side like typical headlights in the past were designed like or is there only a vertical adjustment. I haven't had reason yet to adjust my lights but I also haven't used it much at all in the dark either, however I did have someone flash me right after I bought the truck and found that odd as its not like I had any weight of consequence in the truck or had modified anything which I did slightly after as per doing a slight adjustment on the front torsion bars which did raise the front end slightly. The adjusters I do see which would be for up/down are quite easy to access, be it a 6 mil bit on a 3/8 extension or a typical 6 mm allen wrench, yes it has the Philips drive but it is plastic after all and pretty dinky looking.
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
