So from surfing the forums I’m thinking this rhythmic click that I am hearing at idle every half of a second or so (almost like an old clock) is due to the high pressure DI fuel pump?  Is there a fix for it to stop the clicking if that is what this noise is?  Thanks.
6 minutes ago, Matt Grz said:
Awesome, thank you.  Do all of the 5.3’s do it?
I have 5.3 and it does the same. I had no clue what it was so took it to the dealer to ask, they confirmed the sound and said it was normal. They even showed me another Silverado with 40k miles and it was slightly louder.
Awesome, thank you.
My 2019 custom TB 5.3 does the same thing especially cold sounds like a belt coming around(pulley) then making a click every revolution. 27,000 miles on mine done it since new.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
