I bought my truck used and I was looking to fix the dash lighting and headlight switch backlighting.  I found a connector behind the removable dash face cover that was just hanging and nothing near it that looked like it would connect to it.  The connector had four wires so I used a multi-meter to try and read if any of the wires were grounds or had power.  In the process I tripped the ABS and Brake light on the dash.  Now those lights remain on all the time when the truck is running.  I was thinking I might have blown a fuse but have been unable to find one blown.  Any help would be appreciated.
you probably need a scan tool that does abs, it may be as simple as clearing any code that set. low brake fluid level will  turn those lights on too
you need to be cautious probing unknowns.
That statement holds true for so many things in life🤔😬
  • Haha 1
I'm freaking rolling over here.... haha!
  • 4 weeks later...
The mystery is solved.  The four wires are for the 4WD which my truck is not equipped and the ABS and Brake lights were both illuminated because of two fuses that had blown.  I must have over looked the fuses after the lights first came on.  One was in the Engine compartmant fuse panel and the other was in the panel on the end of the dashboard on the drivers side.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
