On 1/27/2022 at 10:04 PM, Phobby said:
Changed leaf’s, added the helper leaf contacts off the frame, axle for dual tires to support the weight (I’ve seen 2500 wheels crack), larger breaks.
2500 to 3500 SRW capacity is really close bc tires and wheels limit capability.
Here are the numbers straight from Chevy. I'm sure the GMC numbers are the same. Now these rating would of course be for a completely stripped down work truck. On an AT4 or Denali the payload would be less because they have a lot of weight in the options. I have a fairly nicely optioned LT because I don't like leather and my payload is still a hair over 4k lbs for my truck.
TOWING CAPACITY
Compare the capabilities offered with each of the 2020 Silverado 2500 HD engines.
2020 Silverado 2500 Engine
Maximum Conventional Towing
Maximum Fifth Wheel/Gooseneck Towing Capacity
6.6L V8 Gas
14,500 lbs.
17,370 lbs.
Duramax® 6.6L turbo-diesel V8
18,500 lbs.
18,510 lbs.
PAYLOAD CAPACITY
Let the 2020 Silverado 2500 HD work hard for you to help you get those big jobs done.
Maximum Payload Capacity
6.6L V8 Gas
3,979 lbs.
Duramax 6.6L turbo-diesel V8
3,715 lbs.
TOWING CAPACITY
Equipped with the Duramax engine, the Silverado 3500 delivers exceptional capabilities.
2020 Silverado 3500 Engine
6.6L V8 Gas
16,800 lbs.
17,200 lbs.
20,000 lbs.
35,500 lbs.
PAYLOAD CAPACITY
Whether you have single or dual rear-wheel drive on your heavy duty Silverado truck, you’ll find carrying capabilities that can handle the toughest loads.
6.6L V8 Gas
4,534 lbs. (single); 7,442 lbs. (dual)
4,217 lbs. (single); 6,610 lbs. (dual)
TOWING CAPACITY
6.6L V8 Gas
14,500 lbs.
17,370 lbs.
18,500 lbs.
18,510 lbs.
PAYLOAD CAPACITY
6.6L V8 Gas
3,979 lbs.
3,715 lbs.
TOWING CAPACITY
6.6L V8 Gas
16,800 lbs.
17,200 lbs.
20,000 lbs.
35,500 lbs.
PAYLOAD CAPACITY
6.6L V8 Gas
a bit more research time of about 30 seconds would have given you correct numbers on the different models. A SINGLE REAR WHEEL 2500 vs a SINGLE REAR WHEEL 3500 is not a huge difference. You’re comparing as I correctly said above a SINGLE REAR WHEEL 2500 to a DUAL REAR WHEEL 3500. Big difference.
Not sure what you’re talking about. The info I posted shows both the 3500 SRW and DRW numbers. I was not comparing a 2500 SRW to a 3500 DRW. Next time maybe you should read more carefully before you respond with a smart a## comment
Edited by finn5033
No, I’m pretty sure he’s right. The towing table you had clearly was showing DRW capacity. An SRW 3500 is not rated to tow a 35,000 lb fifth wheel - that’s the DRW number.
50 minutes ago, Another JR said:
My bad on 3500 towing chart. The payload chart I posted shows both. Either way the smart a## comment wasn’t necessary.
The whole topic of the post is 2500 vs 3500. Since there are two models of 3500s and only one 2500. But as I mentioned in my original comment the single wheel models are close in all specs. 3500 single wheel puts you in CDL territory, then you might as well buy a Dually and tow whatever you want easily.
Edited by Phobby
On 2/8/2022 at 3:45 PM, f8l vnm said:
besides the 2500 HD vs 3500 HD on the door, nothing different to the eye.
OP is looking at Denali's and on Denali's and AT4's just say DenaliHD or AT4HD on the doors, no place on the truck does it say 2500 or 3500, has been like this since 2011 when the Denali was introduced to the HD line.
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,318 Guests (See full list)
