Has any one installed a Pulsar LT on a 2021 1500 that didn't come with the auto stop start?   And how did it turn out?
Love it, i barely touch the gas at a stop and my truck wants to break the tires loose, definately worth the upgrade not just for the auto stop start disable but the throttle response and turning off DFM
1 hour ago, SC4R3C120W said:
Does anyone know if you need to keep the pulsar connected to keep the changes?
Yes you do.
I installed mine today. Is there a minimum on the tire size it will allow, mine are currently 31.6 inches but unless I'm doing something wrong, I can only go down th 32 inches during peogramming.
  • 4 months later...
When setting tire size the first number is inches then after the sweep it’s asking for decimal .1 to .9.
Yes that is correct.  I am aware of how to set the new tire size, my question is can it go below 32 inches?  Mine stops there and won't let me put it in at 31.6.
