Thanks for letting me in fellas! I have a quick question on this headache........I did the swap, and I'm still having problems with it still running on 6 cylinders. Can you tell me what I'm missing besides not having the right ecm ???
did you use the 8 cylinder wiring harness and it plugged into the ECM?  if so change the ecm to the one for the 8, if you used the 6cyl harness it may not have the correct number of terminals in the injector plug
Um I read before doing this that it wasn't gonna be that hard and it's not hard it's confusing and aggravating. Becuz 1st I went to buy the motor compartment harness out of a 98 vortec 5.7 Tahoe. Wiring was a little jacked up but I made it work at least I thought so ...anyway didn't get that ecm from the wiring from same vehicle so I have a buddy that kinda does shade tree mechanics and he had a ecm from a 98 Chevy 1500, didn't cut it this is how I noticed the v6 was still in it. I don't know where. So I've been through with this harness bcuz of the bad luck I have. So I pulled the harness and went and bought a 99 harness and it's in perfect cond. But my whole main question is will that 99 harness interfere with my 97 fuse box in dash? And the 97 350 ecm that I'm getting tomorrow
98 harness only fits 98 according to GMparts.com. I know because I'm replacing mine. the application description is on that sight but you may need a part number to look it up and that may be difficult because they use your VIN to look it up. the 98 harness came with the underhood fuse box and does not connect to the interior except for the bulkhead connector and the ac wiring that plugs in behind the glovebox so as long as the bulkhead connector is the same you are probably ok with the interior fusebox
it's not an easy job changing the harness, lots of leads come out of the main harness and trying to keep them untangled and routed properly is a test of my patience and I've been doing this almost 50 years
the only differences in the harnesses may just be some of the connectors are different. check carefully to make sure its going to work before you start the install if using a different year than the truck and engine. I don't think I would have attempted what you are doing without having the donor vehicle available to get any thing I needed off of it
Okay so I bought a 97 Chevy 15oo 5.7 ecm and it seems like it's doing okay. Sounds alot better when idling. Now my question is this since it's doing a little better what else do you think would cause it to sound like a miss.
Okay 1st of all I said I bought a 99 harness bcuz all the ones from 96,97 and 98 we're all messed up but, is the 99 a confusing getter for the 97 fuse box in dash? And why does it seem like a miss when idling???
so as I found out it could cause problems as the terminals on the bulkhead connector are used for different things. I'm having problems and it's from the same year
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
