2021 - Chevy Silverado Trailboss LT: I want to power some LED rock lights that would normally be connected to the positive and negative posts on the battery, but only have them come on when the fog lights are turned on. This way, the rock lights act as courtesy lights when you lock and unlock the truck since the fog lights come on and have the rock lights only come on when I press the fog light button from inside.
Instead of connecting directly to the battery, can I:
1. Connect the positive wire of the LED rock light controller box to post 87 on the relay (and ground the black wire to the body)
2. Connect a wire from post 30 on the relay to the positive terminal on the battery using an inline fuse (5 amp, which is the original amp of the inline fuse if I connected directly to the battery)
3. Run the ground wire from the relay post 85 to the body
and here's the big question...
4. Use a micro2 add-a-fuse adapter and connect to the fog light fuse in the engine compartment, with a 5 amp fuse to connect to post 86 on the relay, to "trigger" the lights to come on?
wiring_diagram.pdf
  • 5 months later...
Quote
On 7/15/2022 at 8:31 AM, Dresari702 said:
Chris--did you ever get this worked out?
According to your diagram, Relay #30 should go to 12v (battery) and Relay #87 should go to (+) LED controller.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
