Just brought home my first truck last night. 2022 Sierra 1500 SLT, Premium Plus and X31. I am new to this world….
I am about to begin its transformation to black out, CAI, Bed Cover, Black Exhaust tips, Hyperdip trim & wheels, etc, etc.
Easy question for you pros…as well, I want it to have a better stance. I am going to keep the 20” wheels and tires but want it lifted. Is the rear end 1” higher…therefore a 2” level in the front essentially equals a 2” kinda lift?
Then if I want to go to an overall 3” lift I would buy a 1” rear and 2” front?
sorry for the Noobness, I am huge advocate of learning from these forums!
Tried to add a photo but is just keeps posting as solid black…will try later
Edited by Stealthall
I went with a 2" levelling kit for the front, so I think it's more like the rear is 2" higher.
Factory rake is 2" on 1500s.  A 2 inch leveling kit will get you level.  Anything over 2" will have the front higher than the rear, so taller blocks would be ideal to bring both up higher and level.
2 inches is pretty much the absolute safest on stock upper control arms.  If you want to go over 2" in the front, get arms.
under the front shock lift kits are the easiest thing out there,  even simpler with 2wd, you dont even have to remove the wheels. do the world a favor and get the headlights re-aimed, stock HIDs are awful to other drivers at night, it sometimes gets my road-rage into the redline with some of these lifted punks.
Stock CAI is good enough, why waste 300-450 on a useless upgrade
Edited by pokismoki
Just a 2” in the front is going to make it nose high. Did mine like that, didn’t look right, and wound up putting 1.5” blocks in the rear. Looks great but does have a little rake.
If you want it to “look” completely level, I’d try to find 3/4” or 1” blocks for the back to go with the 2” donut in the front. You want the front 1-1.5” higher than the back. My 2 cents.
This is true. I have a 1.5" on my Denali and its level.
If you are interested, I am selling an extra kit.
https://www.gm-trucks.com/forums/topic/254349-pro-comp-15-inch-leveling-lift-kit-–-63230/
19 minutes ago, Stealthall said:
I would be interested…but I ordered Motofab 2” level kit today. Isn’t that the same?
Except for that guys kit is 1.5" where as your motofab kit is 2".
As I said earlier, that 2" motofab front kit with the donuts that go on top of the springs isn't going to look right without something in the rear. I never measured as I only did it for aesthetics but the body lines look nose high with just the 2". If I had to do it over again I would probably have gone with the 2.5" motofab kit with 1.5" rear blocks. That'd be perfect IMO. That said, if you are patient you can get 1" blocks off Amazon, but they are on backorder, hence why I went with the 1.5"s. At the end of the day a ball hair here and a ball hair there makes all the difference.
Best of luck, going to look better than the stock stance as long as you put on some kind of rear blocks.
For those that are lurking and future reference, you are better off going with a 4" lift if you are paying someone for the install. Better bang for your buck. If you are doing it yourself, 2.5" donuts (going to be a ****** to get in) and 1.5" blocks are the call IMO.
I can be patient - link to the Amazon blocks?
I cancelled my order and can order this….
https://www.americantrucks.com/jm-sierra1500-250-inch-front-150-inch-rear-lift-kit-fr8192025.html#customer_reviews
fit the bill?
I did the 2" in front, then was a little nose high, then did 1" lift block in rear sits level now.
12 hours ago, Stealthall said:
That oughta work.
10 hours ago, Matthew Freeman said:
Hey Im looking to install a 2.5” level kit in the front and 2” block in the rear from https://suspensionmaxx.com/product/smx-gm925rm on my 2021 High country 1500
then I want to run 295/55r22 on my stock rims…any input on if the tires size or will they fit/rub?
I’ve got 275/65/r20 which are a 34.1 inch tire, 11” wide on stock 20’s and they barely rubbed at full lock. Needed to zip tie the liners and now they don’t.
295/55r22 are a 34.8” tire and 11.8” wide. You do the math. They are going to rub. But you should be able to get away with moving/heating the wheel well liners and not have to cut or do a body mount chop. I’ve seen plenty of people running 35’s on a stock suspension who claim they did nothing and they fit.
You should be fine but might have to break out the heat gun, modify the liners and/or mudflaps if you don’t want any rubbing. So worth it though as ~35” tires and a small lift on these trucks is the best thing you can aesthetically do to them. Too much lift = too much wheel well unless you put on 37’s which presents a whole host of other things you need to do to properly run them.
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 828 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
