Just brought home my first truck last night. 2022 Sierra 1500 SLT, Premium Plus and X31. I am new to this world….
I am about to begin its transformation to black out, CAI, Bed Cover, Black Exhaust tips, Hyperdip trim & wheels, etc, etc.
Easy question for you pros…as well, I want it to have a better stance. I am going to keep the 20” wheels and tires but want it lifted. Is the rear end 1” higher…therefore a 2” level in the front essentially equals a 2” kinda lift?
Then if I want to go to an overall 3” lift I would buy a 1” rear and 2” front?
sorry for the Noobness, I am huge advocate of learning from these forums!
Tried to add a photo but is just keeps posting as solid black…will try later
Edited by Stealthall
I went with a 2" levelling kit for the front, so I think it's more like the rear is 2" higher.
Factory rake is 2" on 1500s.  A 2 inch leveling kit will get you level.  Anything over 2" will have the front higher than the rear, so taller blocks would be ideal to bring both up higher and level.
2 inches is pretty much the absolute safest on stock upper control arms.  If you want to go over 2" in the front, get arms.
under the front shock lift kits are the easiest thing out there,  even simpler with 2wd, you dont even have to remove the wheels. do the world a favor and get the headlights re-aimed, stock HIDs are awful to other drivers at night, it sometimes gets my road-rage into the redline with some of these lifted punks.
Stock CAI is good enough, why waste 300-450 on a useless upgrade
Edited by pokismoki
Just a 2” in the front is going to make it nose high. Did mine like that, didn’t look right, and wound up putting 1.5” blocks in the rear. Looks great but does have a little rake.
If you want it to “look” completely level, I’d try to find 3/4” or 1” blocks for the back to go with the 2” donut in the front. You want the front 1-1.5” higher than the back. My 2 cents.
This is true. I have a 1.5" on my Denali and its level.
If you are interested, I am selling an extra kit.
https://www.gm-trucks.com/forums/topic/254349-pro-comp-15-inch-leveling-lift-kit-–-63230/
19 minutes ago, Stealthall said:
I would be interested…but I ordered Motofab 2” level kit today. Isn’t that the same?
Except for that guys kit is 1.5" where as your motofab kit is 2".
As I said earlier, that 2" motofab front kit with the donuts that go on top of the springs isn't going to look right without something in the rear. I never measured as I only did it for aesthetics but the body lines look nose high with just the 2". If I had to do it over again I would probably have gone with the 2.5" motofab kit with 1.5" rear blocks. That'd be perfect IMO. That said, if you are patient you can get 1" blocks off Amazon, but they are on backorder, hence why I went with the 1.5"s. At the end of the day a ball hair here and a ball hair there makes all the difference.
Best of luck, going to look better than the stock stance as long as you put on some kind of rear blocks.
For those that are lurking and future reference, you are better off going with a 4" lift if you are paying someone for the install. Better bang for your buck. If you are doing it yourself, 2.5" donuts (going to be a ****** to get in) and 1.5" blocks are the call IMO.
I can be patient - link to the Amazon blocks?
I cancelled my order and can order this….
https://www.americantrucks.com/jm-sierra1500-250-inch-front-150-inch-rear-lift-kit-fr8192025.html#customer_reviews
fit the bill?
I did the 2" in front, then was a little nose high, then did 1" lift block in rear sits level now.
12 hours ago, Stealthall said:
That oughta work.
10 hours ago, Matthew Freeman said:
Hey Im looking to install a 2.5” level kit in the front and 2” block in the rear from https://suspensionmaxx.com/product/smx-gm925rm on my 2021 High country 1500
then I want to run 295/55r22 on my stock rims…any input on if the tires size or will they fit/rub?
I’ve got 275/65/r20 which are a 34.1 inch tire, 11” wide on stock 20’s and they barely rubbed at full lock. Needed to zip tie the liners and now they don’t.
295/55r22 are a 34.8” tire and 11.8” wide. You do the math. They are going to rub. But you should be able to get away with moving/heating the wheel well liners and not have to cut or do a body mount chop. I’ve seen plenty of people running 35’s on a stock suspension who claim they did nothing and they fit.
You should be fine but might have to break out the heat gun, modify the liners and/or mudflaps if you don’t want any rubbing. So worth it though as ~35” tires and a small lift on these trucks is the best thing you can aesthetically do to them. Too much lift = too much wheel well unless you put on 37’s which presents a whole host of other things you need to do to properly run them.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 484 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
