I just picked up an old clapped out 06 sierra 1500.   I have an old Actron that i used on my 95 and 99 s10's.   However, it wont even turn on when plugged into
this 06.  So im assuming i need a newer one.  What is the preferred scan tool everyones using these days?
If it worked on your '99, then it should work on your '06 as OBDII became a standard requirement from '96 on up. You may not have all the bells and whistles as you would possibly have with a newer one, but you should still be able to pull codes. Sounds more like you have a power/ground issue to the scan tool.
 Ok thanks. I thought It should atleast turn on. I'll look into it.
I'll search for the pin out and go from there.
Tech-2, you need a bi-directional scan tool to talk to the computers on your truck and run the built in tests, take data logs, view and test everything and do programming if necessary.  This type of tool along with the shop manual will pay for themselves after the first repair or two even if you have someone else do the work.
A tech-2 as in one you would find at the dealer?  Or are there any clones or other bi-directional scanners that work well?
Long ago Bosch and Vetronix shipped Tech-2 production offshore to China and while GM has moved on to the MDI and MDI2, China is still making them.  Tech-2 is inexpensive and handy and like Evan says, there are other options out there as well.  The limitation with exclusively using HPTuners is that it does not talk to the Body and possibly the Chassis modules.  The Tech-2, Snap-On Solus, MDI, etc. talk to every module.
That is correct HPTuners has limitations, Tech-2 would be way cooler.
I need to find one, just haven't had the time
On 3/10/2022 at 8:40 PM, EightTrackHits said:
Yes, make sure the software for the PCMCIA car is 33.004.  IF you can get the old TIS2000 software to work on an old Windows XP or Windows 7 laptop, you can do programming for GMT800s right from there.  If not, and if you had to do any programming, you do it online now but Tech-2 is used only as a pass-thru device so a modern laptop would be required or a long CAT5 cord!
You don't have to worry about any of that for day to day diagnostics, only programming.
Edited by swathdiver
  • 4 months later...
On 3/10/2022 at 6:40 PM, EightTrackHits said:
Interesting, since that one says right there:
"Tech2 Notice :
1. It Can Only Support 12V Cars, No Trucks"
This one should NOT work on "Trucks".
There is also this:
"Q: Can Tech2 work diagnose 2005 GMC - Sierra 1500 truck?
A: Want to use our tech2 to diagnose truck, you need to buy an additional truck adapter, because our GM tech is compatible with truck, but only packed with the car adapter."
Edited by ABQ-Jammer
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
    • Great info here thank you. I just joined, we have a 2014 Silverado truck we bought about 4 years ago with less than 5,000 miles on it. It has approximately 24,000 on it now. It appears to have all the standard issues that people are talking about. Occasional charging problems especially using 110 volt, occasional blinking triangle where nothing will turn on when first starting the truck but it will reset itself if you wait 10 to 15 minutes. Noisy coupler between the flywheel and the generator. Our truck is speed limited to 74 mph, is there any way to change that? The latest issue we have been dealing with is when driving long distance on the highway at full speed the generator does not keep the batteries charged. The meter will go into the yellow/red border Zone for charge status and the yellow triangle will illuminate solid but the generator will not keep the battery charged, not sure why the controller doesn't tell the gas engine to increase RPM to increase generator output it usually stays well below 25 kilowatts even though the battery is discharging and I have to slow down the highway to 45 mph and eventually pull over and let the truck idle to charge the battery so I can continue driving at speed. Has anyone had this issue before or have any idea how to diagnosed it? When via Motors was around it they were very helpful at troubleshooting. This becomes much if the Terrain is hilly and you're towing a small trailer
    • I have the GMC accessory (REV) cover installed by dealer. Ordered with the truck.  They did a very good install job, can't find a single issue. Some water gets in around the tailgate but no where else.  You can see daylight around the tailgate but that's not the covers fault.  Installation is means everything. Guys at my dealer were seasoned pros, not inexperienced here today good tomorrow types, like many dealers employ for these jobs.   I don't mind paying for a professional job.
    • Like others have said, they will all leak. Mainly at the corners.   I have owned several and the best has been my current one. Revolver x4
