I've had one since May 2019 - the vinyl is fine, the only issues mine has is the felt is starting to come loose up towards the cab end of the cover, and the metal runners are coming up a bit at the tailgate end so that there is a bit more water that comes in around the tailgate corners. It does help that my truck sits in a garage and has a lot less uv exposure than trucks that spend a lot of time outdoors.
Looking for feedback from users of this bed cover who have had it for more than 3 years. The "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Can't justify the steep price to replace it with another one if that's the expected lifespan. Better alternatives are welcomed as long as they roll up to the front bed wall.
Thanks! I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades. I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet. It wasn't connected to anything, though (I tried swapping in an outlet from another van). I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006. I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play. Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
