I been searching the forum for an hour or so, so forgive me if this is something that's been repeated. I have an 07 Sierra new body style, 4x4 vortec max. I recently did front end work and a brake job(calipers, rotors, and pads). The ABS and traction control never worked since I've had the truck. It never worked because it's been unplugged so I plugged it back in. With the ABS plugged in, I get random brakes being applied without me doing it. Anybody got some direction for me here??
A scan tool that can monitor and look at the ABS system would be wanted.
Having a bad wheel speed sensor wouldn't cause these issues as those just throw a light on the dash. Possible there is an issue with the ABS unit itself.
That's what I was figuring on. I got my brother in law coming lager with the HP Tuner software. I was hoping there was some nitpicky thing that somebody could point me to
HP Tuners can help with the engine/transmission stuff but can't read the ABS system.
You may be ahead to pay a local retail automotive place the hour for troubleshooting.
HP Tuner system gave me a code for a bad "brake pedal position sensor"... seems to have fixed the problem, drove around for about 30 minutes and never got any unintentional braking
    250.3k
    90Nine4One
    90Nine4One
  • Who's Online   1 Member, 0 Anonymous, 351 Guests (See full list)
