I am looking to find the right torque specs when working on the jobs for my truck. I currently would like the torque specs for the exhaust manifold bolts to engine and the stud torque
Quote
Tighten the bolts a first pass to 15 N·m (11 lb ft). Tighten the bolts beginning with the center two bolts. Alternate from side-to-side, and work toward the outside bolts.
Tighten the bolts a final pass to 25 N·m(18 lb ft). Tighten the bolts beginning with the center two bolts. Alternate from side-to-side, and work toward the outside bolts.
What studs are you talking about? If you are talking about the heat shield ones just tighten them down. No torque spec needed.
