I have a 2007 GMC Sierra Denali with the 6.2l. It has about 190k miles on it. About the last 10k or so I have been dealing with the P0011 and the stabilitrak lights. I did several deep forum dives and have replaced the following. The position sensor, actuator and magnet....did not fix it. Then I dropped the oil pan and replaced the pickup o-ring....no luck. So then I decided to replace the magnet and actuator again (first time wasnt with OEM due to availability). After the last the oil pressure has been reading high (60-70) and the light stayed off....for awhile. Came back on today. Truck has NEVER driven poorly during all of this, but still throwing codes.
I have no idea where to go from here. It seems this is a fairly common problem but not a straightforward repair.
Any ideas are welcomed.
Thank you!
why are you chasing op issues for something that has nothing to do with the engine?
I'm not really sure what you mean. The p0011 code is the camshaft position sensor code. A quick Google shows that it frequently results in the stabilitrak light coming on at the same time. The fixes recommended that I can find start with the sensor, magnet and actuator and then the oil pickup o-ring.
Possible it's the wiring in that harness that is the problem now, you've replaced everything else.
Again, when it gets weird suspect the wiring, grounds, etc. I don't know jack about the stabilitrac system; I haven't had any problem with mine; I sure don't understand why oil pressure would have any bearing (no pun intended here) with a traction issue. I just read a description of the system and it's about applying the anti lock brake system to wheels that are slipping, the stabilitrac system can also sense when the vehicle is out of control and can affect steering according to the article I read. How that impacts with engine oil pressure unless oil pressure is used to tell the computer the engine is actually running or or not but there are other sensors that can tell the computers that like the RPM and cam position sensors/systems; maybe the vehicle uses more than 1 sensor to determine engine status...
https://www.auto.com/advice/what-is-stabilitrak
Edited by dna9656
1 hour ago, dna9656 said:
Again, when it gets weird suspect the wiring, grounds, etc. I don't know jack about the stabilitrac system; I haven't had any problem with mine; I sure don't understand why oil pressure would have any bearing (no pun intended here)in a traction issue. I just read a description of the system and it's about applying the anti lock brake system to wheels that are slipping, the stabilitrac system can also sense when the vehicle is out of control and can affect steering according to the article I read. How that impacts with engine oil pressure unless oil pressure is used to tell the computer the engine is actually running or or not but there are other sensors that can tell the computers that like the RPM and cam position sensors/systems; maybe the vehicle uses more than 1 sensor to determine engine status...
Honestly I have no idea how or why they would be related either. The code that pops up in the system is P0011 which is the camshaft position sensor. EVERY time this code trips, the stabilitrak light comes on. Who knows why, but it seems pretty common unfortunately. I will have to start looking into the wiring.
No fix yet. I am actually having a hard time finding the replacement wiring harness. I bought the one that was supposed to be for my truck but it is 3 pin and my truck has 5 pins. I also replaced a brake switch behind the brake pedal as I read that my be it...no avail.
I'll continue to update if I find anything.
  • 3 months later...
  • 10 months later...
On 6/27/2023 at 2:30 PM, Janne Svensson said:
Did someone find a fix for this??.
I have the same problem.
So here's an update to this post. I have replaced everything I can think of and everything I've read online related to this code. I've replaced the sensor, actuator and magnet x2, the oil pickup ring, the oil pressure sensor, the brake pedal sensor, the fuel pump and the camshaft position sensor wiring harness as well as multiple oil changes. No luck, light still comes on. The truck has still never run poorly during all of this but the light continues to come on with the same codes.
What kind of oil are you running?
If I was in your shoes, I would sign up for the shop manual at AllDataDIY and following the troubleshooting guide for that code.  I would buy a Tech-2 as well if the simple diagnostics didn't work.  It would have paid for itself already in your case.
I run mobil1
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
