I just bought a 2022 Silverado 2500HD with the 6.6 gas engine. Can anybody tell me when i can start pulling my 8000 lb camper with no restrictions. Owners manual says on the 1st towing trip to not go over 50 mph. By the time we go camping we should have around 1200 miles on the truck. 50 mph is a little slow considering speed limit is 65 mph on way down to the shore. I dont want to cause an accident. Thank you, Mike W.
I don't know what your manual says, but that's where I'd go to find out.  Years ago, the standard break in mileage was 500 miles before you towed.
Heat.  Diffs produce lots of heat during the first 500mi of break in.  They also will produce lots of heat during initial towing.  I'd get the trailer hooked up after you put 500mi on it to get it "broke in" with a trailer, and then before you do your camping trip change the oil as it also says.
When my 2020 was new, it sure had a pile of various driving before the first tow. That happened between 500-1000 miles. Towed like normal, normal speeds, etc. Trucked performed great pulling a 42' 15000lb fifth wheel on that trip and multiple others.
There’s a good reason the manual recommends not towing in the break in period, and it is primarily related to the differential. Heat is part of it but really a by-product of the break in process. However, it also aggravates the conditions during break in by thinning the oil.
When the differential ring and pinion are new, the gear tooth contact area is very small, creating very high contact pressure. This causes oil film breakdown and surface wear, which eventually wears in the contact point, spreading the tooth contact pressure and reducing the local surface stress. If the differential is highly loaded before this wearing in has been allowed to slowly occur, the high local contact stress can cause spalling of the tooth surfaces at the contact point.
If spalling occurs, best case it will cause a noisy differential with reduced life, and worst case it can cause tooth failure due to the created stress concentrations.
instead, you want to run the differential lightly loaded until the gear contact patches have worn in to some extent, spreading out the force and reducing the contact pressure. Once this has occurred to some extent, the gear teeth can withstand the higher load assocIated with towing. GM has recommended a particular minimum number of miles for this. More is better.
No doubt you should follow GM's recommendations. But note that there is not a single guy who uses these trucks for work (landscapers etc) who give a seconds thought to "break in". They buy it off the lot one day and it's working hard the next day.
Agreed. I was just explaining why you don’t want to do that and why you probably don’t want to buy a used truck from someone like that. If they weren’t pulling heavy weights up long climbs, and not applying max torque (like pulling a big boat out of the water) it probably is just fine.  There is a legitimate physical reason to break it in, though.
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
