Hello,
I purchased a 20' GMC Sierra Elevation with the 2.7 in late December of 2021 (with 18k miles), currently it's 30k miles from the driving I do! Most recent purchase for it was a truck canopy for my overlanding build that I attend to put the truck to do! Since it's basically rare for 2.7 owners to exist... we're here!
I went with the 2.7 for mild towing and decent MPGs, plus the torque is great! I've owned two Subaru Outbacks prior. Hard to go back to anything small after this...
Excited to be here!
  • 3 months later...
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 484 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
