I am looking for locations of speakers in my 2020 WT, I know the doors are 6x9 but is there any others in a standard cab with a IOR radio?
I am looking to add as well if there is only the two speakers. What is a good speaker setup to put behind the seats and where else can I add speakers besides the doors???
Thanks in advance
New guy here, but maybe I can help.
My recently purchased 2021 WT came with the IOR radio and crappy speakers.  ...The radio does not have balance or fade controls, but does have a 3-band equalizer.
....Doing my research here, I learned I wasn't the only one to complain of the poor quality sound.
I replaced the 6x9 door speakers with Kenwood KFC-6966S 3-way's ($60) and the sound is incredible with the factory radio.
Falsely thinking I had dash speakers, I bought Kenwood KFC-X2C speakers ($80) for the front corners of the dash.  ....Upon disassembly I found no front speakers, but I was surprised to see there was factory-installed wiring for the speakers present, so I installed the Kenwoods.  ....They are a perfect fit.
The IOR radio is powerful enough to power the 4 speakers.  ...Sadly, without a balance/fade control, the small dash speakers drowned out the 6x9's.  ....I am installing  L-pads so I can adjust the volume of the dash speakers separately.  ...This should allow balance/fade to be adjusted for the fronts.
I have considered mounting speakers behind the seats, but don't feel I need them.  ....There is plenty of power in the factory amp, and it will pump out LOTS of volume.
Adding rear speakers without having balance/fade control is one step backward IMHO.
Many of the songs on my USB flashdrives would not play, so I had to convert the WMA files to MP3 format.  ....Apparently the IOR will not read WMA files.
    • Follows the motif on the Sierra EV.  Satin finsh to the lower bumper area, painted above:   Elevation       Denali
    • Not exactly what I was hoping for, but I do like it. I wonder if they'll bring back Smokey Quartz Metallic? 🤔 https://gmauthority.com/blog/2026/06/here-is-the-all-new-2027-gmc-sierra-1500/
    • Whoever greenlighted the work truck matte black front bumpers on every trim but the AT4X should be fired!  I was hoping that was an AI mistake, but just realized they were on every model of the 2027 Silverado too.     Some parts of the interior do look premium, but the Denali Ultimate dashboard looks like an afterthought.  At least they appear to have lost the microfiber the high end Silverado models showed, but the '27 High Country dash looks better than the Denali.
    • New member here. I am researching a read-first event-recorder concept for late-model GM V8 trucks. This is not a sales post. There is no product link, price, preorder, or mailing list. I am trying to determine whether the underlying problem is real before building anything.   Has your truck ever had a brief problem such as: - rough running or a momentary misfire - an oil-pressure warning or unusual pressure event - reduced power or a brief stall - a U-code or lost-communication problem - a symptom that disappeared before the dealer or independent shop could reproduce it   If so, I would appreciate the following details: - year, model, engine, and mileage - what happened and under what conditions - whether a DTC and useful freeze-frame data were stored - whether the shop was able to reproduce it - what the eventual confirmed repair was, if known - what additional information would have helped the diagnosis   The concept being evaluated is a removable leave-in recorder that continuously retains a rolling window from before and after an event. It would not tune, reflash, clear codes, or change the vehicle calibration.   I am also not claiming that it could predict lifter failure or see every internal ECM variable.   The real question is whether continuous event history would add enough useful evidence beyond freeze frame, GDS2, and existing scan tools — or whether it would simply be another unnecessary gadget.   For owners and technicians, which problem would make something like this genuinely useful: 1. intermittent misfire or AFM/DFM-related behavior 2. oil-pressure events 3. lost communication or electrical faults 4. none of the above Please be blunt. Negative feedback is just as useful as positive feedback.
    • No tears over the SLE and SLT trim levels disappearing but I kind of loathe the "Elevation" name. It's a truck--skip the elegance.   The slab-dashboard design is decidedly different. Almost has a Hummer flavor to it. "Professional Grade" seems to be leaning very white-collar, tech-driven these days moreso than blue-collar, functional design.   The Silverado would be my choice between the two new trucks. Pleased with the engine lineup in both. The GMC is a little "too much" for a truck, IMO, and the Denali borders on ridiculous - but I do know there are buyers for luxury trucks out there. It's just not my speed.
