I just replaced the door hinge pins and bushings on the driver’s door because the door was sagging. After doing that, I adjusted the striker because it was sitting a little too low. I got the door aligned with the striker so it actually closes without force, but now the door is sitting too high. The top of the door is above the upper body line, which is causing air to whistle in through the door seal. Is there a way to fix that, or do I have to bend the hinges? I’ve tried googling and all I can come up with is how to replace the hinge pins and bushings. Thanks for any help.
Rick
is it possible someone bent the hinges trying to make up for the worn bushings? I know the body side is welded to the pillar, is the door side welded to the door or is it adjustable? you might want to have an autobody guy take a look if it's welded too, they know all the tricks to line stuff up
I’m pretty sure the hinges aren’t bent. I had them out and took a look when I had it apart. It was sagging pretty bad before I put the new pins and bushings in. It just lifted it up a pretty good amount. I thought it was kind of odd, but I’ve never replaced these before, so I wasn’t sure if this has happened to anyone else or not.
Oh, and I’m pretty sure they’re welded on. Edit: I almost forgot…they’ve been replaced at least once before. They weren’t the originals.
Edited by Rick C.
Forgot info.
so if they are welded both sides the only way to adjust the door is by bending the hinges . if you drop the striker does it help? the latch may have a little bit of adjustment but may not either. a well equipped body shop should have the tools to align the door by bending the hinges. seems to me I saw a tool for that in 1 of the tool catalogs
I know I had to adjust the striker up because it wouldn’t latch without slamming it after I replaced the parts. I’ll double-check the hinges when I get home in the morning. I’m pretty sure they’re welded. If they are, I’ll do some searching to see if I can find a tool like the one you’re talking about.
I believe I found the tool you were talking about. My wife left before I could look at the hinges, though. I’ll look at them tonight after she gets home. Hopefully I can get that tool and see if it’ll align the door better. If not, then it’ll be going to a body shop. You’re right. The whistling will drive me crazy. Lol
If the holes in the hinges where the pins go are worn bad then the doors will sag.
That’s the thing. It was sagging to begin with. So I changed the hinge pins and bushings, and it actually lifted the door HIGHER than it’s supposed to be.
What are we driving? What model vehicle? If either side of the hinge has bolts there should be some adjustment possible by loosening the bolts and lowering/lifting the door accordingly, you'll need a floor jack with a 2 x 4 between the jack and the door to hold the door at the right height. If the door side of the hing has bolts there may be shims between the hinge and the door. If so remove the shims. Back in the day  I have seen hammers put in the hinge area and the door pressed towards the vehicle. This BENT the door UPWARDS to correct for a sagging door. I don't recommend this as the hinge area of the door will start to "oil can" Shims are best on bolted hinges. Keeping the hinge pins and bushings in good repair and lubed is essential to good door action. Other than the weight of the door causing the hinges to wear and lack of lube causing the door to drag pulling on the door when getting in/out of the truck bends the hinge face of the door; this weakens the metal. So when getting in/out don't hand or pull or use the door in any way to get in or out of the truck. Get a A pillar handle or one above the door inside the vehicle.
they are welded both sides , no adjustment so ...the only option is bend the hinges I think ,but the auto body guys know. You said they had been replaced before, the doors or the pins?
    JimmyB4
    JimmyB4
  • Who's Online   1 Member, 0 Anonymous, 754 Guests (See full list)
    • I’ve own several successful businesses. I’ve bought homes and lived in different states. I’d witness several generations buy homes and survive in different economic circumstances. You get awful sippy when people have different experiences than you do. You live a life. I’ve lived a life. It seems our experience has been different. You can point out generalized statistics. Some people learn how to thrive when the odds are against them. Living in different states does make a difference in a persons quality of life and economic outcomes and opportunities. That’s a fact Jack. It’s my truth, my life. Hard work and long hours the right environment made my families life easier. And yes moving to a different state increased the odds of that happening. Stats are generalized. People who thrive don’t make excuses. They beat the odds. Others get mad and point to those statistics. I guess that’s you. My post pointed out how you helped people beat the odds. Somehow your panties got in a wad. Go figure.
    • Good question, I don't remember for sure but I believe it was the HD. I will check and get back to you.
    • Point of the post sir was that while both wages and cost are rising EVERYWHERE; the cost is rising faster EVERYWHERE than the ability to buy EVERYWHERE. We're not going down the location rabbit hole. I'm aware of what economic migration is. I've lived in four states including Texas.   It's what "Purchasing Power" means.   I'm not telling you what I think. I'm telling what the government, your government, data shows.   It wasn't an argument. It wasn't a suggestion. It was a statement of FACT. You are absolutely entitled to your own opinion. Your not entitled to your own facts. If you and I were, they wouldn't be facts.    fact /făkt/   noun Knowledge or information based on real occurrences. "an account based on fact; a blur of fact and fancy." Something demonstrated to exist or known to have existed. "Genetic engineering is now a fact. That Chaucer was a real person is an undisputed fact." A real occurrence; an event. "had to prove the facts of the case." The American Heritage® Dictionary of the English Language, 5th Edition • More at Wordnik   If you'd like to disagree call your Senator or Representative and let him know his departments are in error. But you and I? We are not doing this.
    • Probably a one and done post, but do you have a CEL on the dash? Was having issues with my transmission, fortunately only a week, and it turned out to be the transmission harness. Valve body was in good shape, so new harness with all the sensors attached, new fluid, and filter. Seems to have worked so far?
    • Two interesting tidbits of information which are NOT related were just released.   One, regarding the possible thrust bearing issues / engine failures with the 3.0. Demonworks just did a segment in which they believe they may have found "a" or "the" cause of thrust bearing failures: A missing thrust bearing. If the engine doesn't have all its thrust bearings from the factory, the missing bearing can cause extra play which ends up destroying a nearby thrust bearing which then sends metal through the engine.       Of other importance, Lake Speed Jr released some interest information regarding oil weight selection for the 3.0. Comparisons of:   AcDelco 0w20 Dexos D Mobil 1 ESP x2 0w20 Dexos D Mobil 1 ESP x2 0w30 Mobil 1 ESP x4 0w40. Mobil Delvac 5w40   Spoiler alert: The Mobils are PAO Ester -base and the ACDelco is a Group III base. Mobil shows lower wear in their tests for similar weights. Additive packages between 20-30-40 weight ESP's appear to be the same, but only 0w20 is Dexos D licensed. Wear is even more reduced with 30 and 40 weight ESP although all perform very well and resist shear and provide very similar viscosities within temperature operating ranges in the 3.0.   There are even more surprises, so just go watch it.
