So new user here. I have a 2016 Silverado 2500 with the 6.0. All other engines are covered,just not the 6.0. Is there a reason for that?
What's your question about the 6.0?
If it's because nobody is posting about it, then that's because it is an awesome engine and never breaks.  Only issue is mpg isn't the best.  :)
22' Thor CHEVROLET EXPRESS CUTAWAY VAN - 2014 3500  6.0L V8  blew up at relatively low ~40,000  miles, rod bearing failure , GM long block replaced under warranty but I was renting it out to a travel company and suspect drug cartels were using it to run smack around west US.  Suspect rental company did not change oil as requested.
I sold it once engine repaired by Galles Chevrolet  in ABQ.
9 hours ago, steelerdude15 said:
Are you referring to the engine not being covered warranty wise or there not being a lot of posts on here regarding the 6.0?
Not being allot of posts about it. I dont have the factory warrantee,but a dealership 2 year warrantee .
Ya im thinking the rental company had something to do with it and it blowing up,lol.
  • Haha 1
And ya no matter how light i am on the gas steady and easy breaking, cant get past 11.1MPG. Ouch,haha.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 561 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
