I have a 2018 Sierra RCSB 5.3, 4x4 that I added Kooks 1-7/8 long tube headers and green catted y pipe too. I'm having trouble with the y pipe reaching the Borla ATAK catback. It seems to be a couple inches too short. Has anyone else had this issue?
I had a similar problem getting the kooks ypipe to connect. The ball joint just wouldn't tighten up enough to close the gap and not leak. I had a muffler shop weld on a flange joint instead. Not as flexible, but there is another flex point downstream, and no problems over 10k miles so far.
Longer exhaust hangers/bushings should should allow you to move the catback frontwards enough to get it to fit.
Yup, I have that problem. I contacted kooks and my understanding is that I have over tightened the y-pipe to header connections.
I've been meaning to take a rubber mallet to the y-pipe to break the connection (ball/socket joint). Bolt up the cat back first and then "snug" it back up to the headers. Ball/socket connection doesn't need much torque (just enough to hold it in place); heat from the exhaust will do the rest.
Edited by M1ck3y
Thanks, for the suggestion.
My y pipe was nearly 3" short. I slid the mid-pipe from the catback forward and had to pull it out of the hangar to reach. It's a little jury rigged at the moment. I was working with Kook's tech support, but they turned me over to the CEO who suggested cutting it up and putting a 3" wide clamp there. Not thrilled about that, but not bashing them either.  I think I've decided to put a resonator there before the muffler anyway to cut back on the sound.
My y pipe was that short before i even snugged up the ball joints to the headers. I'm a little disappointed in the customer service for such a premium priced product thus far.
Yeah I hear you, I'm just quoting what Kooks said to me; Mine might be just as short as your's is. I ended up jamming a 2x6 bewteen the axle and the muffler to force it forward and bolt it up 😜
I have a borla 40004s muffler I might try and fit in there.
In hindsight I should have gone with ARH.
Edited by M1ck3y
I tried ratchet strapping it together from the exhaust mount to the transmission support, but I didn't like it pulling the exhaust tips under the truck.
The worst part is it caused me to cancel my date with the tuner, and now I can't get on the schedule for 2-3 weeks.
Now it sounds like something is loose in the drivers side greencat. Metallic rattling noise... any ideas? Thanks!
I know on mine when the exhaust is cold the clamp's at the ball/socket joint will sit loose, and can make noise if you hit on it. Other than that... it could be the substrate is loose in the cat :dunno:
The rattle is definitely coming from the cats (now both sides). I have checked for loose connections and anything touching the headers. I can stop the rattle by touching something to the cats while it's rattling. Touching anywhere along the headers and primaries has no effect. Sent a video to Kooks at their request this was what they said to check.
Regarding the y pipe, I'm exceptionally disappointed in the craftsmanship and customer service of Kooks. I received no other responses from them on these issues. I slid the mid pipe forward and removed it from the hanger mount just so the ball and socket would seat well enough to clamp together. I decided to have the y pipe and the mid-pipe to the cat back cut and a Vibrant resonator welded in place. I can't believe how much of a difference the resonator made on the sound of the headers! Love the sound of this combination.
Thanks all for your help!
    • No.   That would be an LT and higher trim.  Passive entry.   WT and Custom do not get this feature.
    • Mediocre, how much did they lose on the poorly conceived EV strategy?   I wonder how much the stock price is being 'inflated' by all the buy-backs?   Cadillac literally looks like a brand without a rudder, no clear goals or product direction - performance or luxury? I guess performance because we can throw a small block in whatever we can and call it a day. Certainly not luxury when a Denali or High Country is reasonably cross shoppable. The Celestiq - no way - no vehicle can command quarter million prices when something wearing the same badge is on the buy here pay here lot across town.   Notice the 'base' Escalade doesn't even come with the 'leather-appointed' seating surfaces.   Hummer EV - fail Silverado EV - fail Sierra EV - fail Bolt/Volt EV (The most successful EV cancelled, restarted, cancelled, whatever its current status it)   Hybrids - none Sedans - none Medium duty - not anymore Minivan - none Coupe - none Convertible - none CUVs - 20+/-   6.2 Recall that landed squarely on the GMs highest seller - and specifically the fattest margin higher trims of the Yukon, Escalade, et. al. The most critical product line they fumbled big time. In the Escalade segment, are those buyers forgiving GM for a bad engine and patiently waiting for the fixes and dealing with the headaches? Nope, they dump them and go straight to the other premium brands.   In the ENTIRE GM portfolio how many aspirational vehicles are there? Corvette, Escalade (quickly being superseded by the obvious better value Denali)...   I posted somewhere else... what if Cadillac left the luxury game and became a performance brand similar to AMG or (gasp) Ferrari? Cut all the entry-level and base models from their line up and focus on the V-series or Blackwing or whatever they call it now. Of course, those would have the pre-requisite luxury and technology as standard equipment. This opens the floor for Buick to step in/up as the luxury brand (like they are in China), no 'performance pretenses' get rid of the 'entry-level' models with equally 'entry-level' power trains and become the Maybach to Cadillacs AMG. With those two brands effectively out of the way Chevrolet, the 'entry-level' brand has the floor to itself and GMC can take over as 'professional grade'.    Now each brand has a focus, no in-fighting, clear direction, and customer targets.   Just need to sneakily slide Corvette into the Cadillac brand and dump the vestigial script writing.
    • I can't get enthusiastic about the 1.5T (or the 1.3 or the 1.2), I won't drive a CVT. But the stupid things sell in volume.
    • There is a big difference in motorcycles and vehicles - nobody needs a motorcycle, they WANT one. That WANT is the most powerful force to drive price upwards.   I've hated every iteration of the Equinox, a prime example of GM laziness. It excelled at absolutely nothing, barely competitive by every metric. At least the latest generation looks decent.    I want to like the Buick Envista, but that pitiful engine plus FWD only is a BIG NO for me, I don't care how good it looks.
    • For as much hate as Ms. Barra receives on here, she sure is a shrewd businesswoman....
