I have a set of Fog lights that I pulled from my 2021 Silverado before I traded it in. They are aftermarket and look pretty cool.
I will give them to someone in Utah - Hand deliver / pickup - no shipping - I'm in Herriman.
Visuals of them can be found in this video:
