12 hours ago, Stand By said:
I have a different experience. I tow similar to you. 5000lb boat, dru weight+trailer,fuel and gear pushing towards 10,000. Night and day from my previous 5.3 4 door. Empty, the 5.3 gets better around town. On the freeway, they're comparable, except the  6.6 HD is way more stable and accelerating to pass at speed limit+ is much quicker in the 6.6. It is doggish getting out of the hole, due to being torque sensing and not giving full torque without a load behind it.
Yeah I was never a fan of the 5.3  had an 07 and 14,  moved onto Ford and Ram after those and which had better motors.  While there is some lag I feel, the 6.6 seems strong out the whole,  really just mid range sucks bad on the truck.  I expected sub par towing experience when towing compared to the duramax, but sort of disappointed in all around performance while not towing.  Definitely not as quick and nimble without a load as half ton unloaded.
It would be great to see an actual dyno chart on power at the wheels.  What GM shows for the engine power output and how the truck feels in the real world, are two different things.  Maybe its a drive-train package/programming situation.  If I give the truck a good swift kick in the gas... pedal, it will perform.  Kind of reminds me of a lazy horse.
On the other hand, if that is what it takes to get good fuel mileage, I won't complain.  Gas prices are killing us.
Here you go
https://www.gm-trucks.com/forums/topic/228184-2020-66l-gasser-dyno-pull/
Edited by vucelick
Accuracy
What gets me is the 6.6 is has a minimal advantage over the 5.3 in hp and torque numbers.   I get the 6.6 is more HD with the iron block and all but that motor shoud be pushing 450 plus along with the torque.
The motor is suppose to be torque sensing, so hopefully when you truly need the power, it will compensate. Either way, the components are heavy duty, as well as the overall truck. Pulling my boat with the 5.3, I was reminded frequently it was back there. With the HD, it was more of an obtw.
No i get it.  But the stability portion has more to do with 3/4 1 ton frame rather than the motor.  Put the 5.3 in the HD truck short of longevity you probably wouldnt notice a large difference motor wise.
These engines probably have the capability and should be pushing 450-500hp with 500-550 torque
There is a pretty significant difference between those two engines imo
21 hours ago, vucelick said:
Thanks for posting this!  I'm pleasantly surprised by that graph.
The truck doesn't feel like the chart shows (very similar curve to the GM chart).  Which lends to what @Stand By mentioned regarding "torque sensing".
It is also very probable that I'm gauging this engines power against my last truck which was a diesel (5.9L Dodge).  That is not in anyway a fair thing to do on my part.
I really do like this truck.
No I get that.  But doubt you notice the difference on the average given the performance specs for both.   50hp more isnt doing much
Hp doesn’t mean as much as torque and there is way more torque with a better curve and better gearing to utilize that power better.
For sure,  but your talking minimal numbers here.  And if you look at the dyno numbers of the 5.3 vs 6.6 they are very close.  At 2500 the numbers are identical and at 4k-4500rpm the 6.6 is minimally better by 30-40 ft lbs.
Again not going to argue longevity between the two, but I can promise you will not notice the difference between the two in practical applications.
Only GM puts a motor in a truck that has less juice then the dodge 6.4 that has been out for 7-8 years and the ford 7.3 tremor.  Then again GM is usually playing catch up
Only hope in the 24 model, GM mates the 6.6 with the ten speed and programs the motor to put out more power, which would probably make the power pack satisfactory or better in class, which as of now its not.
They already announced it will have the 10spd
The 6.6 is essentially a beefed up, but detuned version of the 6.2. 6.2 being one of the best recent engines introduced. But if you want better numbers than the other guys, you could go this route. https://www.enginebuildermag.com/2021/01/gms-6-6l-lt-iron-block/
Without researching the 6.4 or 7.3 for longevity myself, I'm inclined against the 6.4 at least. The 6.6 suits my needs, and has a lot o new features to preserve it long term, hopefully.
6.4 is a really good motor,  been out for 8 years now.  But has aluminum parts and coated rods and such.
    Chris80s
    Chris80s
  • Who's Online   5 Members, 1 Anonymous, 827 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
