I just replaced my drivers side AFM lifters after getting a P0307 code. The lifter was definitely collapsed.
When I re-installed the fuel pump, I did NOT have it at TDC. Now when I try to start it, it sputters and is throwing 6 different codes pertaining to open circuits. (P0090,PooC8,P0202,P0204,P0206,P0208.)
I changed all the seals on the injectors.
 My question is, does installing the fuel pump not at TDC affect this? Could it possibly be that simple?
I have been working on this for a week now and am getting frustrated.
Any help is much appreciated.
Todd
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
