8 hours ago, ESierra said:
Thats what I'm actually planning as well. Keeping the stock 20" wheels and wrapping them around 33" tires. I don't like the "wide tires" stance on trucks, doesn't fit for me. I'm planning on a 3.5" lift with upgraded struts. I wonder at how much of a mpg hit I'll see. I'm estimating 2MPG less. I'm getting about 23.5 and roughly 450 miles each fill up!
Ya I waffled hard about just sticking some e-rated snowflakes on the factory 20's and could be quite content, it was a close runner up. I really only need the body higher for some proper outdoorsman clearances. My factory black 20's will likely go up for sale by end of summer. And with the 0 offset on the new 17's and going skinnier tire I will only push out further by 0.7" which with a 4" lift will be ideal (not look too inset) but this combo also gives an additional 1.5" clearance over stock on the inside edge of the tire. I'm guessing by September will see mine all done with lift and the pizza cutters. I've pulled the chin spoiler as well. But guessing I won't take too big a mpg hit with the skinnies I'm going to. Will update as we go. Here's the start, some debadging and added limo tint to back window and a brow, and my paddle board rack/tonneau cover. https://www.instagram.com/chasinflags/
I'm a huge fan of the elevation black rims 20", they look great. I recently found a video of them with A/T tires and lifted. I think it looks great. Maybe at some point I'll consider purchasing different rims, but too expensive for what I want to do.
On 6/21/2022 at 5:54 PM, pepe48134 said:
Nothing extreme but I did a 2" lift with Bilstein 5100's and Nitto 34" Tall 275/65R20 w stock wheels on my 22 refreshed Silverado LT 2.7L. Nitto is the only 34" tire you can get in non Light Truck load and it only weights 4 lbs more than stock LT tires are all 13-18 lbs heaver each  and its that unsprung weight that really kills MPG.  Fuel economy was not effected in my case and I looks way better than Stock IMO. RIdes better too.
Another question- what did you have them raise the front bilsteins to?
Had them set at the 2" height . its the 2nd to highest. the highest setting is 2.5" but is not recommended with stock control arms. at the 2" setting the ball joints are not at an extreme angle, in fact its hard to tell any difference from the stock angle.
The 2" setting was a true 2" lift on my truck (I measured before and after with stock tires and it was exactly  2")
Edited by pepe48134
clairification
Finally got the 1" blocks in the rear.  I got the stocks blocks from the previous generation truck They are 1.2" and I milled them down to 1" used the stock bolts from the pervious truck too and they are the right length.  A local shop gave me the blocks out of their scrap pile and the U bolts were ~$8  each.
IMG_7650.jpgTop is just Bilsteins in front Bottom is with 1" rear blocks
Edited by pepe48134
comment
I got mine installed the other day.
Bilstein 5100s and new rubber. IMG_2472.thumb.jpg.77c4c93b2133eb66ad8180a70925b8ed.jpg
Looks good. What rubber do you go with?
Falken Wildpeaks AT3/W; Old tires were Good Year Wrangler SR-As, and these are only slightly more loud. It's noticeable, but not unbearable. I'm looking forward to testing them in the snow, in a few months.
Edited by ESierra
22 custom 2.7 with 4” readylift sst lift.
Edited by 4banger
Looks good.
My updated 2022 trailboss is a 2.7ho. It comes with a 2” lift and oversized tires from the factory. It’s just as strong as the 5.3’s I use at work and fuel economy is better…..
Edited by Texcl2
Forgot to post a day time picture. Using bilstein 5100s the front is pretty much level with the back. ( I sold the cap)
Hey guys I have 2021 GMC Sierra Elevation 2.7
I did a 6 Inch rough country lift
20 inch Fuel rims
35 inch America’s Rugged M/t
Read LED light bar
Police horn/pa system
2 10 inch subs under rear seat
5% tint all around 20% on windshield.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
    • There's absolutely a mountain of profit in catering to the "I do my own research" crowd, people who are certain they know better. And I don't mean there isn't data to support that 0w40 produces less wear product than 0w20 in an engine like the 3.0 Duramax, that only feeds them the assurance they need. Again, my whole thing with oil selection is, sure, 0w40 or 0w30 produces less wear product. Are we talking the difference between the engine lasting only 100k versus 200k? Or are we talking more like, if the engine will already go 350k on a good 0w20 regimen recommended by the OE, is using 0w40 going to get us to 355k, assuming we can even get the rest of the truck to last that long, meanwhile sacrificing the first 5y, 100k in powertrain warranty. The answer isn't easy, there are tradeoffs.   I willfully use 0w20 Dexos D for this reason, knowing that a 0w40 will produce slightly less wear. I don't believe the delta in wear product is meaningful over the lifetime of the engine, and I place much more importance on driving style and overall feeding and care of the engine as a whole. It's the mentality that someone can abstain from alcohol their whole life which is an amazing boost to health by itself, theoretically. But if they're sedentary, that lifestyle choice will most likely kill them young despite their other, concerted efforts. Maybe someone doesn't drink AND they are the perfect picture of health and activity AND they use 0w40 AND they treat their engine perfectly. If living until 130 years is the goal, sure, do that. But it's going to be a really old truck falling apart around a good engine for that last 30 years, without a doubt.   I watched Demonworks' other video on the 100k+ 3.0 Duramax that had dealer 0w20 changes on what appears to be OLM-prescribed intervals (8-10k).   The QR codes are still present and readable on the main bearings. That's how little wear it has.   That's not proof that anyone else should stick to 0w20, but it's confirmation, for me, that 0w20 is perfectly acceptable to use in these engines.
    • 1Based on independent testing of OE 0W-20 in the Peugeot TU3M Wear Test as required by the dexos1 Gen 2 specification.
