On 6/22/2022 at 1:51 PM, 4banger said:
Well that's the stigma anyway. It's just not how it works though. Case in point, 1989 dodge introduces the cummins turbo diesel, nice long stroke low hp but way more torque than hp rating and at way lower rpm than the naturally aspirated competition. In an era of big block v8's as the alternatives. And that tiny little 5.9 liter displacement could have a big camper on, 4 horses in the trailer behind and head to the mountains getting good mileage while the v8's wheezed so hard and sucked fuel at open bar rates. The reason that cummins was able to do that with it's anemic initial ratings of 160/170 hp and 400/410 ft/lbs torque...was because the turbos eliminate elevation...they only lose 0.05% power per 1000' but the naturally aspirated 3% per 1000' so elevation largely eliminated and easy to equal the big block competitors if not surpass them.
The 2.7t is the same formula...long stroke turbo with way more torque than horsepower and at lower rpm than naturally aspirated peak torque numbers. Stay with me here...I live Calgary Alberta, 4000' elevation. Where I live I have 22 ft/lbs more torque than the 6.2 and I have it at lower rpms. I'm sorry but this little boosted 4banger is far more truck designed engine than either of the 2 v8's which are both short stroke motors fyi. The 5.3 isn't really in the same league when elevation comes into play, they are equal at sea level but the 2.7 walks away from there. The 6.2 still has 62 more hp at my elevation despite that 22 ft/lbs torque deficit but it's burning 30% more fuel around town here, I know as I just returned a 2022 6.2 rental that I just put about 1000 miles on and picked up my 2.7 two days ago and closing in on it's first tank of break-in at about 260 miles right now and just under half tank on it's first tank! and it's 30% less fuel by the mpg rating on both trucks dashes back to back. And this torque pull is effortless...torque spins those tires, that's why diesels are preferred for the big trucks...it's not the diesel, it's the turbo's that make them special and able to pull down respectable mileage and power combined, turbo regardless of gas type is going to run lifts and tires and loads better than the v8's at most elevations above sea level where 60% of us live and with less gas consumed for everything but the longest steepest heaviest pulls.
You seem to know what you’re talking about
I have a question
I got a 2023 TB Lt with the 4 cylinder 2.7 turbo
Came stock with 275/65/18 tires and 3.42 rear axle ratio.
If I install 295/70/18 will it affect performance significantly?  I do not care about MPGS.
I’m concerned about sluggishness.
(already know the 296/70/18 tires clear UCA’S on stock 18” wheels)
I have a question
it's just rolling mass and drag, you've added more contact patch(drag) and whatever the rolling mass is, I know the stock 275 65r20's that came on my custom were 78.4 lbs per corner as I weighed them before and after I changed them, I ended up doing something super rare and went to a lighter weight combo and went 4 lbs lighter per corner with a 17" lightweight wheel and skinny tire the exact same height. I gained performance and mileage even going to load range 3 all terrain but most aftermarket wheels are absolute slugs, heavy wheels and heavy tires, most aim for looks vs performance enhancements, things in motion want to stay in motion, heavier wheels/tires don't want to change direction as easily and take more work to get up to speed and more work to slow down (brakes)...having said all that, your turbo will spin them every bit as good as the v8's, you've got more torque at lower rpm, the truck least likely to feel them is the diesel at it's got 460 ft/lbs at a mere 1500 rpm which is half of the the 2.7's peak torque rating
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 478 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
