Hey guys! Im looking into doing some easy power mods to my 2016 5.3L silverado. I would love to get atleast 400 whp out of it but I dont know what i should do. a lot of people are doing cams and intakes, would that get me there? I dont want to go forced induction as im low budget (under 2,500). any guidance would be appreciated!!
Thanks in advance
Cam, springs, lifters, ported heads, LT2 intake and LT5 TB, long tubes, y pipes true duals. But the most important part…. Find you a tuner that knows how to tune these trucks.
Start simple. My last new truck was a 2014. I could still do a lot with a hand held tune. There’s a tuner who’s a sponsor on this site. Forget numbers it’s about seat of the pants feel. Once you get the tune and turn off cylinder deactivation. Exhaust sound helps with the senses. It sounds faster. Budget minded start with a loud muffler. Is your truck E-85 ready? That’s cheap horsepower. You haven’t spent a lot of money yet. Not enough? Gear it. 373, 456 seat of the pants feel just lite up. Still close to budget. All of what I mentioned so far can be self taught. That’s where the real savings are.
400 wheel horsepower on $2,500, not going to happen.
That's talking like 100hp gain here. Going to need a different camshaft, different intake, probably a slightly higher stall converter and switching over to E85 and headers.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
