Have a 2018 GMC Canyon 3.6 SLE that has a minor issue shifting from 1st to 2nd gear after first drive in the morning.  Back out of the driveway then start forward, no problem. Then after stopping at the corner stop sign 1/4 mile away the truck hesitates for a brief moment before shifting to second gear if I take off quickly after the stop. Hear a clunk noise but it shifts.  If I take foot off break, start rolling forward then press the accelerator it seems fine.  After initial stop it is not an issue. Just the initial start / stop.
I have owned multiple GMC / Chevrolet cars and trucks off and on in my life.  Has a 1989 Chevy 1/2 ton, same issue.  Had a Camero, same issue.  I saw another post here that mentioned that GMC and Chevrolet have this "design" anomaly and not much can be done.  I think this is true. But other than this small issue I really like my Canyon, no other issues.  But starting to make me think. I just today received a letter from a "Lemon Layers" group out of Los Angeles about a pending case (#831186) against GMC trucks, mine included.  Lots of issues it seems but don't most vehicles have some sort of issue these days?
My question, what would you do?  Live with it or sell it?
Normal characteristic of the 8 speed.  I'd live with it.
#16-NA-361: Information on Transmission Harsh 1-2 Shift Upon First Start Up/Shift of the Day Under Light Throttle - (Jan 26, 2022)
Condition
Some customers may comment that the transmission exhibits a harsh 1-2 shift on the first shift of the day, typically under light throttle.
Cause
This condition is due to the initial clutch fill time of the 2-3-4-6-8 (C4) clutch.
Information
Some customers may experience a flare condition on the first 1-2 shift of the day or after the vehicle has been parked for several hours. The condition may have developed after the replacement of a complete transmission assembly or the replacement of the stator support to correct a delayed engagement condition. This is most likely to occur under light throttle conditions. Subsequent 1-2 shifts have acceptable shift feel. Replacing transmission components will not correct the condition.
Correction
Important: Replacing transmission components or complete assemblies will not improve the condition.
The first 1-2 shift of the day may be harsh. The customers’ vehicle should be compared to a like vehicle under the same driving conditions. Do Not replace any parts for this condition.
Note: This condition will not impact the designed performance or reliability of the vehicle.
Edited by newdude
Wayne, my newer 8 speed behind the 22' LTD Trail Boss custom 2.7L turbo 4 was starting to do what you describe but faintly at about ~11000 miles.
I suspected the GM Mobil1 HP ATF was giving up the ghost viscometrically and thinning a bit. I changed to Amsoil ATL with my dealers blessing and used their BG machine to change it out at 14000 miles or so.  I have a bit less than 1000 miles on the Amsoil ATL and have tried to force the issue and it's gone. As a matter of fact the downshifts and upshifts are more positive but still super smooth.  I think better than before with OEM M1 HP ATF.
Can't say enough positive about Nick and  https://www.gm-trucks.com/forums/forum/139-synthetic-advantage/ where I sourced my fluids, shipping was free and I got the products in 2 days here in Colorado ( shipped from Wichita KS via UPS).
Condition
Cause
Information
Correction
Initial clutch fill can be improved with a more  stable synthetic fluid, why they went to Mobil1 HP ATF.  The Amsoil ATL is even a better syn base oil and it shows in my Trail Boss 8 speed.
Thanks for sharing all that newdude.  Your contributions here appreciated.
I had to chime in here. Switched to Amsoil fluids for an ATV and a 19 Hyundai Santa FE. No doubt it was an improvement in transmission performance.
Chemistry quality matters!
    • What I think you're saying is there is supply here at home, and in Venezuela, and we could ease pricing if only it were favorable to do so.   Well, yes?   But that's not the current market. Supply isn't what could someday exist, if only, it's what producers are willing to produce and sell at a certain price point.   The national price of single family homes would come way down if we'd just slap together a few million homes this summer.   RAM and GPUs would get a lot cheaper if we just set up some factories to produce a bunch more and stopped using it to build out AI data centers.
    • The turn signal/multifunction switch is faulty.  I've seen a few of these go bad at work.
    • I am experiecing the same issue, I have gone in the setting and disabled rain sensing function but I am still experiencing this. Whe i use my turn signal they will redomly turn on. Sometime they stay on and others times we swipe 2 or 3 times and stop. Its super anoying, escpecially after a fresh wash. Anyone have any advice? . rain-sensing function, but I am still experiencing this issue Sometimes they stay on, and other times we swipe 2 or 3 times and stop.It's super annoying, especially after a fresh wash.When I use my turn signal, they will randomly turn on. I am experiencing the same issue. I have gone into the settings and disabled the rain sensing function, but I am still experiencing this.
    • If we actually used any significant amount of that source in the USA then I'd agree but we don't. We've had that discussion before. We drill and pump more than we use. Thing is, we sell. We export. Gas and Crude. It's more profitable so any shortage here is self inflicted and LEGAL.    I worked a gas plant that has multiple fuel sources available and I worked in the furnace and boiler plant in that facility. I'd had days we swapped fuel types four times in a twelve hour shift which isn't done on supply but on margin. Two of the fuel sources are internally generated. Tail gas and DAK, both of which are sold as well a consumed. We always had more than we needed to run the process but we chose the fuel that produced the best margin not bought at the cheapest price always. A good bit of math to that and back in the time that was done on a slide rule.     I worked the Shale Oil Semiworks of Chevron Research and CONOCO Research in Salt Lake City. That process never went into production although it was very successful. Why? Did we lack oil bearing shale? Nope. Price of crude never made the margins work. That was in the late 70's early 80's. Remember history? What was happening then was a reaction to that situation. It didn't drive it. If so then it's easy. This isn't a supply and demand thing. This is a profit and margin thing and AI rules that now.    In no refining situation that I was ever in would a bomb hitting a well anywhere in the world 'instantly' interrupt or even distress the supply. Most plants have more than a months worth of crude in the tank field and more in pumping stations. That yo-yo could play out over days, weeks and maybe months and have zero impact on plant operations. How many times has this been off and on in the last few months? These people and not stupid. These plants measure down time in hundreds of thousands of dollars per day. They are not sucking fumes or waiting on the next truckload with baited breath. Besides, as I noted, they are for the most part 'vertically integrated'. They own it from the dirt is sits in to the delivery rack and sometimes to the pump. It has a HUGE shock absorber built in. When production suffers, refining wins and when refining is winning exploration is killing. The rest of that crap in the news is a 'news cycle'. Government dipping in to reserves? Oil is stealing their milk money. There's a reason Chevron abandon Venezuela infrastructure and it had nothing to do with security of US citizens. Nationals run those plants. it has to do with MARGINS disappearing to corruption. They are in no hurry to return. Is there supply there? Oh yea. More than enough to offset what is bought in the middle east. Just isn't ???? Profitable.    We have supply. There are places in Illinois you can drive a pipe into the ground and run your homes natural gas furnace on it.    A refinery fire will gum up the supply works but not a localized war where the market is using a limited supply from. Now Europe, that's something other....
    • $4.00 a gallon here now.   Diesel nearly $5.00 again.
