2021 Sierra 1500 Denali
5.3 V8
21k miles
I was driving my truck into work last Tuesday... As I make my last turn, it feels like my engine gives out and I receive "Service Parking Brake", then I get a "Service ESC" shortly thereafter. Engine light also came on.  I was able to limp my truck up the hill and in to the parking lot. The truck was making some serious noises and I could feel the loss of power. No previous symptoms or hint this was coming whatsoever; sort of reminded me of when my timing belt went on Christmas Eve (87 Integra) way back in the day...
I called the dealer right away and let them know what happened. I explained that I could not drive it to them and they recommended calling GMC Roadside Service. I let tehm no that I would need a loaner, but was told they did not have anything for me. I did some bitching and complaining, and 30 minutes later, they had a loaner for me. A three year old Buick Encore that was not fun to drive!
After trying Onstar and told they could not help because I am not registered to their plan, I called roadside and get the automated BS which suggested I use the app. Hung up and tried the app - The app sucks, so I called them back and eventually got a human after 15 minutes - damn glad it was not a true emergency. Anyway... 30 minutes later a flatbed had arrived. I asked they guy if he had enough room or if I should back up the truck to make it easier to get it up on the bed. I started it up and put it in reverse for about 10 feet and I can smell oil, started seeing some smoke - oh ******!
The dealer gets my truck in to the service bay the following day, but no word. I call back on Thursday and was told it was a lifter (same thing I found on my first Google search when it happened). I was then told that they would be disassembling the engine to get to all of the cylinders to see how much damage there was, and I should not expect another update until Monday.
Monday morning, I receive a call first thing to let me know that my truck was ready for pick up. Which means it was dine Friday and I could of had it for the weekend, but no big deal... As it turns out, two lifters, a push rod and gaskets were replaced. It sounds like one of the lifters was actually broken in two pieces.
All covered under warranty, so about $3300 to GMC. It seems there are a lot of trucks out their with or with potential to have this issue. No recall as of yet, but there is a service bulletin from GM to the dealers, and it sounds like they are covering the costs in most cases. I have seen cases that were as low as 3k miles, so every 2021 (maybe more) truck may be in play here.
Just wanted to give everyone a head's up on this - Good luck!
Round 2... Back to the dealer with the same issue just 2000 miles later. So pissed!
Let me guess they changed only one side of lifters and now they get to tear it all down a second time to do the other bank?
I was told that they took care of all the first time around... I mentioned it again this time and followed up with a formal complaint with GM and plan to file a lemon law complaint with the state of CT. Just getting my proverbial ducks in a row in case it happens outside the warranty period. I am trying to document as much as I can to protect myself down the road. Hopefully there are no further issues, but better safe than sorry!
Quick Update... After two weeks, I got my truck back last week. As expected, the original repair only took care of one bank. They replaced all of the push rods and lifters on bank two this time, so I hope the issues are behind me. I filed my lemon law claim with the state of CT and I am awaiting a hearing date. I do not expect much to come form it, but what the hell? At a minimum, it may help if an issue pops up down the road when I am out of the warranty period.
can you operate the truck without it going into DoD mode, so it operates on all 8 cylinders all the time.? usually manually shifting into a gear  below final overdrive will disable this, and might avoide engine issues with the DoD crap
Just like i thought, a stupid bone head directive by gm because of their crap part sourcing and availability issues. No doubt this issue should require both banks to be changed at the same time, not one.
So what are our options if this happens out of warranty?  I am waiting to get mine back after 3 weeks and I am pretty sure they are only replacing the one side.  I really wish GM would come out and let us all know that it will be fixed at no charge if out of warranty.
Yeah that is not happening. Maybe your powertrain warranty would cover it, not sure if that goes to 100k still but if out of warranty GM would most likely not give a dime.
Edited by BIGDOGx
Update: I have heard from the state of Connecticut and my arbitration hearing is set for Dec. 7th. In my claim, I have asked for a replacement truck, so we'll see what happens... Up until yesterday, I had not heard a thing from GM. Now that a hearing date is set, it seems they are trying to get in touch with me. Hmm, wonder why??? I have not spoken to anyone yet; just back and forth phone tag.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
