I have owned a 2006 Silverado 1500 for a couple of months. Installed a new battery about a month ago. Everything was working fine until I went away for a week. Now the truck will not start - it fires and runs for about 1 second and then shuts off.
I've tried all all of the YouTube video fixes, talked to the local GM dealer, dis-connected and re-connected the battery, put a charger on the battery to make sure that it was fully charged - but nothing has worked.
When I first turn the key to on, the theft deterrent light is not on. When I try to start it the theft deterrent light comes on immediately, the truck fires and them immediately dies.
Sometimes, when I turn the key to the on position without starting the truck, the theft deterrent light comes on for less than a minute, then it goes out. If I try to start the truck the theft deterrent light comes back on and stays on.
The theft deterrent light is either off or on - at no time does it flash.
I'm at my wit's end. Can any one help?
There will be fellas along in the morning who know what's wrong.  I've read the posts many times before but my memory fails me.  If you don't see any activity by 0900, give it a bump.
the problem may be with the BCM, MANY recent posts of similar problems but no 1 has posted a fix yet. try disconnecting the battery, turn the key to run, touch the cables together to discharge any capacitors that are still charged then reconnect with the key still on. this worked for me with my friends truck but I think he just got lucky. same year truck and similar symptoms. if and when you figure it out please post what the fix was,
I tried this suggestion today - no luck.  On another forum someone suggested that my ignition key or my ignition key module may be "worn".  Don't know what that means but any opinions are appreciated.
Edited by Wascoman63
We've seen on older trucks the key module get plumb wore out and not work with the theft deterrent system anymore.
Do you have access to a Tech-2 or other bi-directional scan tool?  That's the kind of tool that's going to solve this without salvos of the parts cannon being fired.
In Florida by chance?
I am in Oregon.  I do not have a fancy scan tool but my local mechanic does and he has agreed to do a housecall and bring his scan tool along (I buy him breakfast sometimes).  Will let you know what we find.
Perfect, just what is needed.
@shakenfake Do you remember what the common causes of this is?
I would think it is something with the ignition/key or BCM.
One of my first thoughts is turn off VATs with a tune but that is kind of the bandaid solution
If you take the steering column cover off (carefully its easy to break), there are 3 wires that wrap around the top of the ignition switch and go into a connector.  Pull it, push the pins out and clean the connectors, use a tool to clean the other half of the connector.
I had the exact issues you had, it was hit or miss if I could start the truck or the passlock would engage.  Had to wait 10 mins or so between each try.  Finally got so bad it wouldn't start at all.  I did this about 6 years ago and no issues since.
This is a common issue with this gen passlock.
Edited by Soonerchevy
FYI GMT800 trucks have no chip in the key only in the tumbler assembly. Since the truck starts and quits its the VATs system.
How to Reset the Passlock System on GM Cars
Insert your key in the starter, start you car as you usually would and let it stall. Keep the key in the “On” position. …
Wait until the “Theft Sys” light on your dashboard stays on without blinking. This will take approximately 10 to 15 minutes.
Источник: https://gsi-alarme-securite.com/protection-of-life/how-do-you-reset-the-security-system-on-a-chevy-silverado.html
Well, my buddy brought his full-fledged scan tool over.  The scanner kept saying that it could not communicate with the ECU.  Consistently returned a "Class 2 Data Link Malfunction U1000".
Our guess is that the issue is not in the computer but somewhere in the bus where all of the communications between the various modules takes place.
We checked all of the wires going into the ECU and none are rodent damaged; we check each fuse in both fuse boxes; and we briefly disconnected the Mass Air Sensor to make sure that it wasn't gumming up the works.
So, now I think that we know that it isn't the theft deterrent system.  The vehicle will fire and run each and every time you turn the key, but it runs for just an instant before it shuts off.  My mechanic thinks that the reason that it shuts off is that the computer is not receiving any information and therefore it shuts everything down.
Don't know where to turn next.
the truck I worked on did the same thing, the scanner would power up but not communicate, after trying the remote srart the key wouldn't srart the truck, the blower and the radio wouldn't shut off, no gauges and did the same run for a second, as I said earlier we got lucky that disconnecting the battery fixed it, the problem started when a new battery and starter were installed and fixed itself when I disconnected the bat and went to the parts store for new side terminal bolts, reconnecting the negative terminal I believe the key was on and it sparked a couple times and was back to normal, BCM is the only thing that makes sense to me but I suppose it could be the bus system. I would start by checking the power and grounds to the BCM, good luck and please keep posting your progress, there have been quite a few posts of similar problems but no one n has posted a fix that I have seen
I found some good info on YouTube.
"Class 2 Data" refers to GMs network protocol for communication between the various "modules" of the vehicle.  Each module is a dedicated computer that must communicate with every other module (powertrain, body, doors, AC, antilock brakes, etc.).  They are all interconnected by a single wire that shares data between the modules.  This system is set up to operate on 7 volts, so any higher or lower voltage would indicate that one of the modules is failing - or else there is a problem somewhere along the wire.  If any module is dumping the wrong voltage into the system things can go south in a hurry.
If you want to know more, I recommend a video by a fellow named "Rico L" that is titled "GM Class 2 Data Line Diagnosis and Repair Info".  He does an excellent job of explaining how this all works.
Evidently there is a device under the dash called a "Splice Pack" where wires from all of the modules come together.  They are inter-connected at the splice pack with a device called a "comb".  If you remove the comb you can check the voltage on each of the modules.
I haven't done any more yet and probably won't for a few days as I have family visiting.
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   1 Member, 1 Anonymous, 488 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
