I had to take my 2022 Silverado with the Duramax into the dealership due to check engine light on and they also said there was a recall for the shutters. After they got it into the shop and looked they said in the harness for the shutters a wire was pinched that was causing proper signal for the shutters to open and close. I ask how they fixed the issues and their response was, "We moved the harness to the proper location and moved the wire so it was not pinched and all problems went away." My concern is the wire was pinched now they have moved it to me that has weakened the wire if it was pinched bad enough to not get the proper signal. They claim they did not splice it which personally I am 100% against splices in main wiring harness for a permeant fix especially on a brand new truck. So I wanted to just see if anyone else has ran across this issue yet? I am going to have them show me what harness they moved and verify they did not put a splice in the wire before I take the truck off the lot.
This is the recommended fix from GM:
The fix: dealership service technicians are instructed to add a tie strap to the wiring harness, which will secure it to the vehicle and ensure it does not contact the active grille shutter while it’s moving. These repairs will be performed at no cost to the vehicle owner.
https://gmauthority.com/blog/2022/07/chevy-silverado-gets-service-update-for-aero-shutter-wiring-harness-issue/
Thank you, my only concern is still there was a pinched wire that was causing all kinds of issues in this wiring harness. My main question is shouldn't the harness be replaced if there was even "just a pinched wire" to prevent issues down the road from that wire being weakened?
If the wire was pinched and there is wiring damage, the service "recall" is to replace the aero shutter assembly and re-secure the new wiring.
I would think they should but the dealer told me and I quote, " We moved the harness so the wiring was not pinched anymore to let the wire transmit proper signal, and that was the reason for all the check engine lights for the ECM and TCM was the wire was pinched enough to not let the proper signal to transmit through it."  To me if a wire is pinched that bad then it should be replaced and not spliced. Am I over thinking this issue?
Yes, they have guidlines to follow and thats what they do, some may be pinched alot more than others,road conditions and driving habits, stops,starts etc could have a lot to do with how hard the wires are pinched if they are pinched. Some may be pinched and others may not be.
They are not going to replace parts if not needed. the word pinch itself is a word that can have many degrees of pressure.
Let the dealer perform there job.
As a former service rep for a global company, pinched wires may not have any internal damage. I've seen it several times There are a few ways to verify that too. My question is how did they know a wire was pinched if it's in a covered harness?
  • 3 weeks later...
My issue would be that they are treating you like an idiot.  A wire carrying electricity cannot have the electricity stopped by kinking or "pinching" the wire.  Electricity don't give a damn. If that truly was what caused the money light to come on, then it was not "pinched", it was severed.  They are talking about it like it is a washer fluid hose or something.
I would not be worried about them splicing it.  If the ever splice fails, then the money light will come on again, and then they will replace the harness or the whole shutter assembly.
  • 3 weeks later...
Do you have the actual TSB for this?
I had the CEL come on tonight and the fans are acting weird. Thinking this could be the issue. I have U0284
    B07
    B07
  • Who's Online   1 Member, 1 Anonymous, 859 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
