Hi All,
I have a 2020 GMC Sierra 2500HD Denali Duramax.  I have two batteries, but how do I check for the dual alternator?  Are there two separate alternators or a single alternator with dual generator?  I see the GM parts for a dual generator and a single generator alternator.  One is much bigger than the other.
Thanks in advance!
Laurent
Follow the fan belt behind the radiator.  It will either wind around one or two alternators.  If you have the original window sticker, it will be on it.
Scan the build code QR sticker on the bottom of the driver door frame.  It will show you all of the three letter codes that are the options for your truck.  If your list includes the code KHF, then you have dual alternators.  After displaying the list you can then email the list to yourself to keep for future reference.
On 8/11/2022 at 10:42 PM, Laurent Kim said:
Hi All,
Thanks in advance!
Laurent
Perhaps some of the misunderstanding is because all dmax 6.6's get dual batteries?
All duramax trucks get 2 batteries.
They are (at least on dmax) connected together to act as one big battery.
Single or dual alternators, is the same.
Gasser gets the 170A as standard,
dmax gets the 220A as standard,
both can get dual alternators
 KW7   Alternator, 170 amps
1 -  Requires (L8T) 6.6L V8 gas engine.
KW5         Alternator, 220 amps
1 -  Included with (L5P) Duramax 6.6L Turbo-Diesel V8 engine or (VYU) Snow Plow Prep/Camper Package. Free flow on (L8T) 6.6L V8 gas engine.
KHF         Alternators, dual, 220-amps primary, 170-amps auxiliary
1 -  With (L8T) 6.6L V8 gas engine, (K4B) 730 cold-cranking amps/70 Amp-hr auxiliary battery is required.
Batteries change between gas and diesel too -- the gasser gets the 730's if dual alternators package is added
(standard batteries don't get a code in the guide)
         Battery, heavy-duty 720 cold-cranking amps/80 Amp-hr, maintenance-free with rundown protection and retained accessory power
1 -  Included and only available with (L8T) 6.6L V8 gas engine.
         Battery, heavy-duty dual 730 cold-cranking amps/70 Amp-hr, maintenance-free with rundown protection and retained accessory power
1 -  Included and only available with (L5P) Duramax 6.6L Turbo-Diesel V8 engine.
K4B         Battery, auxiliary, 730 cold-cranking amps/70 Amp-hr
1 -  Requires (L8T) 6.6L V8 gas engine and either (KW5) 220-amp alternator or (KHF) dual alternators. Not available with (KW7) 170-amp alternator.
On 8/12/2022 at 8:44 PM, Laurent Kim said:
I definitely see the main one in the 1st picture, but is the one in the 2nd picture the 2nd alternator?  Would you please confirm?
Thank you so much!
Laurent
You do not have dual alternators.  The second one would be above the power steering pump which makes checking the fluid a bit of a pain.  Had 2 on my 21 and only a single on my 22.
  • 3 months later...
2 minutes ago, Dave's Place said:
ONly a single battery on 2022 6.6L diesel with dual alternators.
That's interesting.  I have a 2021 6.6 diesel with dual alternators and dual batteries.
This is cool information I will look for the QR code. So you just do that with your phone?
Yes.
    C. Hart
    C. Hart
  • Who's Online   3 Members, 0 Anonymous, 519 Guests (See full list)
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
