11 hours ago, lee3090 said:
All ready tried replacing the hood latch
Sorry, did replace, or attempted to replace?
Have you checked for stored codes? May be one linked to the HLS that needs to be cleared.
I put in a brand new hood latch from Gmpartsdirect and nothing changed and I checked for codes and didn’t find any
Age of battery in truck? When they start to fail, you will get random electrical issues.
The battery is from 2018
I would have it checked out, same age as mine and I am planning on replacing my this fall.
It will probaly come back as good, but the factory ones don't have a very long life.
Battery tested good
  • 9 months later...
I have a 2014 GMC Sierra 1500 and mine is doing the exact same thing.  I have had my Alternator rebuilt just a month ago as well as earlier I was getting a "LOW Battery" message at every start up.  The battery is new and is an exact replacement as the factory.  It was replaced after starting to get the "Low Battery" message.  Since it did not change anything and was still starting the truck well, it probably did not require changing at the time.  The alternator was rebuilt and was not failing either but I did it to try to get the "Low Battery" light to stay off.
It seems that the "Hood is Open" message has not taken over from the "Low Battery" message.
I have gone through all the grounds and have also replaced the Battery Voltage sensor with a new one from GM.  I have still not found the cause of this issue.  I have gone over every inch of the wiring of the truck from battery to tail lights and there is no evidence of damage from critters or road wear.  I have also taken my truck to a vehicle wiring troubleshooter company with a great reputation who has upgraded all the modules on the truck and has gone over the wiring and connections and has found no issues or cause for this happening.
I am at a total loss as to why this is happening.
ANY PROVEN FIXES FOR THIS WOULD BE MUCH APPRECIATED.
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
