Just picked up a 2022 Custom Refreshed a few days ago and looking to upgrade the headlights. Judging by the new design it looks like any aftermarket LED headlights for 19-21 wont fit the 2022. Other than swapping bulbs for LED's, is there any aftermarket lights available for the 2022 refreshed model?
Edited by MrMonkei
  • MrMonkei changed the title to 2022 Silverado Refresh Headlight Upgrade Options?
Looking at the usual sources (Spyder, Anzo, Recon) I don't see any yet.  Bulb swapping would be the only option at the moment.
Don't do that unless it is halogen bulbs. LED's and HID's in a reflector housing just blind the crap out of everyone, regardless of what the bulb maker says or how hard they try to mimic a halogen pattern, they just can't. You get splotchy coverage and dangerous driving for others coming at you. Do it right with a replacement housing.
There was a headlight test comparing the outputs of LED's versus halogen bulbs I read recently when shopping for my halogen replacements. The light meter actually read higher (not barely but like 20%+ higher) with upgraded halogen bulbs versus those bright LED's, not to mention coverage was better and cutoff was safer.
Tyler
Edited by Amcguy1970
I got a reply from ANZO that they wont fit the refreshed models. Probbaly wont be until another 6 months or so until someone makes an aftermarket projector for the refreshed.
Tyler
This is true! At this point I will more than likely just retrofit some LED projectors to the stock headlights. I want to make sure they are bright enough at night
On 9/8/2022 at 1:46 PM, SkiDooNick700 said:
So headlights are still not great on these new trucks??
The halogens are terrible! I also seen on Facebook groups that the new refreshed LED's are not as bright as the 19-21 models. The 19-221 models have 3 LED projectors and the refreshed only has 2. Not sure what they was thinking with that.
1 hour ago, mjonesjr84 said:
You'll have to replace the grill as well, but this is an option.
https://www.gen5diy.com/products/2019-2020-1500-silverado-led-headlights
I actually like the 2022 Silverado refresh headlights better than the ones I had in my 2020 Silverado and 2021 GMC.
Headlights were one of the big reasons I got a high country. The headlights on my 21 RST sucked.
Spoiler
Thanks for the suggestion. When looking for a dependable dissertation writing service. Where you may benefit the most from professionals who can correctly direct you and provide dissertation assistance. So I will suggest you this uk-dissertation.com site where you will find dissertation editing service. Here you will get dissertation writing on all the topics, you can take help from this post.
Edited by JeanWilliams
If the front end looks matter, I think the OP should have opted for the LT trim, with an aftermarket light kit running about 3k, the LT trim would have given you that and a bit more. As the saying goes.."You gotta pay if you want to play".
