I had a 2019 with BOSE, just got a 2022 Refresh with BOSE.  I noticed the 2022 BOSE didn't sound as good as the old truck. With some tinkering, I found a few things. I listen to music via Pandora, or YouTube music app.  I noticed in the new 2022 if I listen to music via Android Auto (whether it's Pandora, YouTube music, etc)  the sound quality isn't as good vs listening straight from the app built into the truck.  I adjusted the EQ settings on my phone, and also changed the app setting to play music at "High" quality. ...no change. Any suggestions?  I do like the listening to music straight from the YouTube music app built into the truck, but this costs $15 per month for "app access" plan.  I would rather listen to music via android auto, and the YouTube music app on my phone.. or Pandora, etc.  But again, the sound quality is noticeably worse .  Anyone else notice this?
Which sound system do you have? There's 6-Speaker Base system, 7-Speaker Bose Premium in AT4, 12-Speaker Bose Premium in AT4X and Denali.
And I think Android Auto still uses Bluetooth for audio. I was under the impression that Connecting with AA would mean using Wifi for Audio which has higher bit-rate and better quality. But if I'm listening to music and I turn off wifi on my phone the music keeps playing in the truck.
    • I see where you’re going and I can appreciate that. Statistics can be misleading because of the word average. They say statistics show the average cost of a new vehicle is about 50k. The average monthly payment is close to 1000 dollars a month. That’s statistics for you. I know very few people who pay that.
    • same here , i have a 2020 first gen and the cost to repair these engines far excedes replacement
    • But Grumpy I did show several subdivisions that had homes starting in the 170K range. If you bought a Townhouse or Condo you could go cheaper. Same with a car 3000 dollars in the 70s translates to around 20K today. There are several models at that price. You actually get more for the money. In the 70s I drove a 3000$ car bought a 28K home and made 4.50 per hour. Thank goodness for overtime. Today I could buy a 170K house drive a 20K car and make 25 dollars an hour operating the same machine today. The difference the house, car, machine would be better and have AC. And I wouldn’t be taxed on overtime. And statistically your wife works too. Easing the burden. I thought we agreed to disagree. I brought receipts earlier, showing examples. I think you’re more stubborn than me. I was done with this debate.
