Has anyone that ordered a 22 refreshed Sierra Denali actually have it delivered yet? I ordered one in early January. It was built in May, and I am told that it is sitting waiting for parts in Marion Ohio.  I know there are thousands in the same boat as me, Just wondering if any of these trucks are finally getting transported. Anybody?  Marion has a GM stamping plant, so I don't know why it would be there.
Marion, OH is where most trucks are going to sit in a lot waiting for chips.
I had a 2021 AT4 that was built in Feb 2021 and sat in Marion, OH until it was finally delivered mid-Oct 2021.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
