Anyone have any idea what the software update for the 22 refresh that is being pushed out is about? Any database GM keeps of each version and the update list?
Likely the radio one for the intermittent static caused by a "software anomaly" as well as other fixes.
After the update you should see this I would think:
Go to Setting->About->Build Number to see this page
Edited by newdude
I guess it's still a good idea to get the update even if you're not having issues?
Well after trying mine a couple of times and coming up with a No Update is Available, I am now getting Update did not load try next time you shift into park or see your dealer. So off to the dealer I go.
Mine did the same thing. What did dealer say?
Those of you who this did not work for, when you park are you in vicinity of wifi that the truck can use?
My truck is in the driveway, and my home wifi reaches and is saved in the vehicle's settings. Wonder if that helped.
Funny story, I went to the dealer and made an appt. I rolled into my driveway after being at the dealership, and the software was downloaded and installed when the vehicle was put in park. So it must have started another request for the software. I tried disconnecting the battery, rebooting the radio into Save Mode, tried connecting to the home wifi, but just waiting a few days caused a reload.
Edited by Rocz3cqg
I made the appt for Oct 7th but the truck initiated a software download as soon as I pulled into my driveway. So letting a few days pass caused a reload request I assume.
Did you get the software update?
For the ones that did receive the OTA update, can you post a pic of the build. I checked mine and it shows I'm up to date but it is not the same build as newdude.
Mine updated. What version do you have?
W149E-W163.3.2-QIH22B-515.1 149
What did yours updated to?
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 508 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
