Good evening everyone, this is my first post. I have a 2019 AT4 6.2 with a Pulsar LT installed and I need to get my emissions done, does anyone know if I will fail emissions with it installed? Should I take off and drive over the weekend then get emissions done on Monday? Or am I worrying over nothing?
Thanks for any and all help!
Yes it will fail. Saw a video on Youtube from Lonestar Hawaiian who went to get his emissions checked and had his Pulsar installed and the truck failed. I believe it even said in the Pulsar manual to remove it if you have to go for service or emissions test. It blocks some communication to the factory computer and causes things to fail.
That’s what I saw as well, I guess I will take it off tomorrow morning, go drive around then go get tested.
  • 1 year later...
I can confirm it has to be removed. Mine failed 2 readiness states.  Re move had to drive over 4 weeks and 300 miles for everything to reset.
2 hours ago, kmeleon said:
Had my truck inspected and emissions tested Christmas week. Didn't even think about removing it. Passed with zero issues.
What state/country are you in?
  • 3 weeks later...
FWIW, I went to get my truck tested after work today.
Not Ready...
Figured I'd give it a shot, and it didn't work out, lol
Maryland, Baltimore city testing station, fwiw.
Edited by rel3rd
Add state
Not Ready...
Do you have a Pulsar LT installed?
Sorry, never got a notification of this reply.
Yes, it was installed at time of emissions test. Never even thought to research it beforehand.
4 incomplete readiness items.
Removed it, and within 2 days it showed 0 incomplete, or, ready to test.
Had to wait the week they required, and it passed easily.
Re-installed Pulsar LT the same day.
good to know. I have this and uninstalled the device bc body shop had to run scan tool and resets, and I didnt want any issues. Does anyone know what exactly fails the readiness tests? maybe the AFM delete or stop Auto start?
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,245 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
