9 hours ago, Gavin Faulkner said:
Thank you!
So currently I just got a new stock trans, which they installed and was broken out of the factory.. Which is bad because that was the last 6L80e in the state so i was looking at the Supermatic 6L80e. I can currently only find it for LS motors, i am not sure what would need to be changed to pair it with GEN V LT. Or if there are better options, but that seemed good for my price range and considering we are close with the GM parts dealer in our town. I would appreciate any help
I don’t know too much about trans. But I believe the older 6L80E will not be able to communicate with our generation 6L80…. Totally different. If you still have the original core, I would just send it out and get it built.
On 12/5/2022 at 11:46 PM, CajunFries said:
Even at 550 at the wheels is easy. I was DD mine for about 2 years at 560+ beating the crap out of it any chance I get and it was perfectly fine. Just make sure you use the right tuner that know what they are doing. A lot of trucks don’t run right or last long because of the tuner. Goodluck! Ask away if you got any questions.
do you know if chevrolet makes a performance oriented trans that would pair with the GEN-V model trucks?
I don’t know but I don’t think so. Havnt heard of anything like that. I wish we can swap the 6L90 tho! That would be awesome. But it doesn’t work. Only the 6l90 converter fits our trucks.
yeah, they got a stock one in. so i’m back to stock stuff. gonna get the thermostat valve for the trans, to keep the temps lower for now. not sure when i’ll do turbos, might end up going cam heads down the line instead. but either way i don’t want anymore transmission issues
No need to buy thermostat for the trans. Follow this link T stat flip. Free and easy. I’ve been running this for 3 years now and never have a problem.
good to know, i’ll work on it!
    • Jumped up 15 cents yesterday. $4.15
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
